rontaylor
(Ron Taylor)
January 18, 2020, 10:51pm
1
I have copied this integration into the sensor : section of my configuration.yaml
It runs into errors in the template.
If I comment out the template
# PVOutut
- platform: pvoutput
system_id: *removed for security*
api_key: *MY API KEY has been removed for security*
scan_interval: 150
# - platform: template
# sensors:
# power_consumption:
# value_template: '{% if is_state_attr("sensor.pvoutput", "power_consumption", "NaN") %}0{% else %}{{ state_attr('sensor.pvoutput', 'power_consumption') }}{% endif %}'
# friendly_name: 'Using'
# unit_of_measurement: 'Watt'
# energy_consumption:
# value_template: '{{ "%0.1f"|format(state_attr('sensor.pvoutput', 'energy_consumption')|float/1000) }}'
# friendly_name: 'Used'
# unit_of_measurement: 'kWh'
# power_generation:
# value_template: '{% if is_state_attr("sensor.pvoutput", "power_generation", "NaN") %}0{% else %}{{ state_attr('sensor.pvoutput', 'power_generation') }}{% endif %}'
# friendly_name: 'Generating'
# energy_generation:
# value_template: '{% if is_state_attr("sensor.pvoutput", "energy_generation", "NaN") %}0{% else %}{{ "%0.2f"|format(state_attr('sensor.pvoutput', 'energy_generation')|float/1000) }}{% endif %}'
# friendly_name: 'Generated'
I get this so that proves my system_id and API key are OK.
If I remove the comments, I get this error.
Confused…
Anyone got any ideas?
Delbz
(Marcus)
January 18, 2020, 11:06pm
2
Today I used this instead and it works.
system_id:
api_key:
scan_interval: 150
sensors:
power_consumption:
value_template: >
{% set pc = state_attr('sensor.pvoutput', 'power_consumption') %}
{{ '0' if pc == 'NaN' else pc }}
energy_consumption:
value_template: "{{ '{:.1f}'.format(state_attr('sensor.pvoutput', 'energy_consumption')|float/1000) }}"
power_generation:
value_template: >
{% set pg = state_attr('sensor.pvoutput', 'power_generation') %}
{{ '0' if pg == 'NaN' else pg }}
energy_generation:
value_template: >
{% set eg = state_attr('sensor.pvoutput', 'energy_generation') %}
{{ '0' if eg == 'NaN' else '{:.2f}'.format(eg|float/1000) }}
rontaylor
(Ron Taylor)
January 18, 2020, 11:27pm
3
Thank you.
I now have it working too.
I have a timing issue where my generation show zero id my PVO has not queried Enphase.
That only happens every 15 minutes. So HA show zero.
I will have to fiddle with that. I might have to only query PVO every 20 mins or something?
trial and error.
Thanks again
rontaylor
(Ron Taylor)
January 19, 2020, 1:07am
4
I think it’s peculiar to my PVOutput but “power_generation” is always zero.
It shows up as NaN in my screen dump above so scripting in template is working as it should.
I was looking on an app on my phone "PV Output and power generation is shown there as NaN on the live page but does get it on the “Today Page”?
Weird.
I don’t get it???
Some hours later I decided that the Power Generated was a value I already had coming directly from my envoy integration so just commented that part of the template out.
