PWM Fan interference with Dallas Temperature Sensor
Hi!
I have the following problem:
I’m using a PWM to control a fan. However, with a PWM duty cycle other than 0% or 100%, my sensors do not deliver values but give the following error for each sensor:
[W][dallas.sensor:130]: 'serverroom_temp_3E28' - Scratch pad checksum invalid!
I ruled out hardware or wiring issues, because I have the same problem with only the temp sensor attached.
It is working with a PWM frequency of 1000Hz, however that’s not usable as the coils of the motor are getting noisy by that.
I tried to solve the problem by turning the fans off while I’m updating the sensor, but that also did not help. (see my attached file)
Setup:
  • nodemcu2
  • 4 dallas sensors on D0, 4.7k pull up between 3.3v and D0 as recommended
  • 4 fans on ports D1-D4
Maybe somebody in this forum can help, I’m grateful for every idea.
  platform: ESP8266
  board: nodemcuv2
# temperature
dallas:
  - pin: D0
    update_interval: never
globals:
   - id: fan_1_val
     type: float
     restore_value: no
     initial_value: '0.0'
   - id: fan_2_val
     type: float
     restore_value: no
   - id: fan_3_val
     type: float
     restore_value: no
   - id: fan_4_val
     type: float
     restore_value: no
  - platform: dallas
    address: 0x3500000807BFC128
  - platform: dallas
    address: 0x3A00000808A43428
  - platform: dallas
    address: 0xD800000807C93328
  - platform: dallas
    address: 0x9000000809283E28
    lambda: |-
      id(fan_1).turn_off();
      id(fan_2).turn_off();
      id(fan_3).turn_off();
      id(fan_4).turn_off();
      id(dallas_sensor).update();
      id(fan_1).turn_on();
      id(fan_2).turn_on();
      id(fan_3).turn_on();
      id(fan_4).turn_on();
      id(fan_1).set_level(id(fan_1_val));
      id(fan_2).set_level(id(fan_2_val));
      id(fan_3).set_level(id(fan_3_val));
      id(fan_4).set_level(id(fan_4_val));
      return {};
    update_interval: 10s
# fans
output:
  - platform: esp8266_pwm
    pin: D1
    frequency: 18000 Hz
    zero_means_zero: true
    min_power: 0.3
    pin: D2
    frequency: 18000 Hz
    min_power: 0.3
    pin: D3
    frequency: 18000 Hz
    min_power: 0.3
    pin: D4
    frequency: 18000 Hz
    min_power: 0.3
fan:
  - platform: speed
    output: fan_1
    restore_mode: "RESTORE_DEFAULT_ON"
    on_speed_set:
      then:
        - lambda: |-
            id(fan_1_val) = id(serverroom_fan_inlet).speed / 100.0;
  - platform: speed
    output: fan_2
    on_speed_set:
      then:
        - lambda: |-
            id(fan_2_val) = id(serverroom_fan_outlet).speed / 100.0;
  - platform: speed
    output: fan_3
    on_speed_set:
      then:
        - lambda: |-
            id(fan_3_val) = id(serverroom_fan_top).speed / 100.0;
  - platform: speed
    output: fan_4
    on_speed_set:
      then:
        - lambda: |-
            id(fan_4_val) = id(serverroom_fan_bottom).speed / 100.0;
# Enable logging
logger:
  level: INFO
# Enable Home Assistant API
api:
  password: ""
ota:
  password: ""
wifi:
  ssid: "secret"
  password: "secret"
  manual_ip:
    static_ip: 10.10.0.191
    gateway: 10.10.0.250
    subnet: 255.255.255.0
  ap:
    ssid: "Server-Fan Fallback Hotspot"
    password: "secret"
captive_portal:
Hi! Did you solve this problem? I’m having the same with AC_DIMMER.
If I add dimmer component, dallas stops working with the same error.
UPD. This issue on github and workarounds: ac_dimmer / dallas interrupt issue · Issue #1976 · esphome/issues · GitHub
I am having simular issues with the “nan” after I followed this tutorial ESPHome: 4-Wire PWM PC style Fan Controller Part 1 - Building the Circuit Board - YouTube
I am looking for a solution to stop the nan issues, if the pwm frequency is above 10khz it happens every time the sensor is polled but below this is happens perhaps every 2 or 3 polls.
