I’m building a component that controls two fans speed based on measured temperature.
I am using the ledc library with a ESP32 C3.
Controlling the fans works well.
I am now trying to add an active buzzer that beeps (currently as a switch). This is also using the ledc library as per the example in this link:
But when the buzzer is triggered the fans go out of whack (stop, then stop-start) until I restart.
The ESP32 should have separate PWM channels so I really don’t understand what causes the interference. Any idea?
Code (part where fans/buzzer is configured):
output:
- platform: ledc
pin: GPIO3
- platform: ledc
pin:
number: GPIO6
mode:
output: True
pulldown: True
frequency: $fan_frequency
- platform: ledc
pin:
number: GPIO21
mode:
output: True
pulldown: True
fan:
- platform: speed
output: fan1_pwm
restore_mode: RESTORE_DEFAULT_ON
- platform: speed
output: fan2_pwm
switch:
turn_on_action:
then:
- output.turn_on: buzzer_pwm
- output.ledc.set_frequency:
frequency: "1000Hz"
- output.set_level:
level: "100%"
turn_off_action:
then:
- output.turn_off: buzzer_pwm
