Hi Guys,
I’ve just purchased led dimmed panel with integrated driver and mainboard.
I would like to install it in the kitchen, so I need to move the driver on the top of my cabinet while led panel will be installed on the bottom.
It requires around 1,5m (5ft) cable.
What is the best option to avoid EMI?
I do not want to degrade my zigbee network.
I have 6 wires cable between the driver and main board and 3 wires cable from the board to LED stripes.
I’m going to use shielded cable. Question is if I should keep mainboard close to the led and “long” cable will be used to connect driver, or I can move both main board and driver - long cable will be between the board and led stripes.
