For context — a couple of years ago I built a PID Fan Controller on an Olimex EVB board (for POE support) to control a fan affixed to the top of my cabinet.
I haven’t touched it (or my other ESPHome devices) for over a year for the sake of “if it ain’t broke…”, but found myself rattling through them all yesterday to bump them all to the latest version, just to keep on top of things. For more context, with a newborn on the way, I’m not going to have time in a few months…
Everything else went through fine, however, my fan controller now appears to be stuck at 100% and cannot for the life of me figure out why. I’ve changed nothing in the configuration, other than a few errors regarding configuration changes and deprecations—a single line, here or there.
There is a warning that the fan PWM is configured on GPIO02, a strapping pin, but this wasn’t a problem in the previous build, again, unless framework tweaks…
Below is my entire config for the device, not sure if someone can spot anything glaringly obvious.
Apologies it’s a bit of a dump, I thought it would be easier to print out the entire validated config for context-awareness.
Summary
INFO ESPHome 2025.2.2
INFO Reading configuration olimex-server-cabinet.yaml...
INFO Detected timezone 'Europe/London'
WARNING GPIO2 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
substitutions:
esphome_version: 2025.2.2
device: evb
device__friendly: EVB
pin__tx: '1'
pin__tx2: '10'
pin__rx: '3'
pin__rx2: '9'
pin__can_tx: '5'
pin__can_rx: '35'
pin__i2c_sda: '13'
pin__i2c_scl: '16'
pin__spi_cs: '17'
pin__ir_tx: '12'
pin__ir_rx: '39'
pin__relay_1: '32'
pin__relay_2: '33'
pin__ethernet_mdc: '23'
pin__ethernet_mdio: '18'
pin__hs2_clk: '14'
pin__hs2_cmd: '15'
pin__hs2_data: '2'
pin__button: '34'
manufacturer: olimex
manufacturer__friendly: Olimex
name__friendly: Server Cabinet
description: Olimex EVB configured for monitoring temperature within the Server
Cabinet, and adjusting it's top-case fan.
version: 2025.3.4-1
fan_min: 5%
fan_max: 100%
temp_target: '27.5'
temp_min: '20'
temp_max: '35'
pid_kp: '0.90000'
pid_ki: '0.00135'
pid_kd: '0.00000'
cron_autotune: 0 0 0 * * 6
esphome:
comment: Olimex EVB configured for monitoring temperature within the Server Cabinet,
and adjusting it's top-case fan. (2025.3.4-1)
project:
version: 2025.3.4-1
on_boot:
- priority: -100.0
then:
- delay: 1s
- binary_sensor.template.publish:
state: true
- logger.log:
tag: -.ready.-
level: DEBUG
format: Server Cabinet has announced 'ready'
args: []
- lambda: !lambda |-
id(thermostat).set_kp(id(thermostat_kp).state);
id(thermostat).set_ki(id(thermostat_ki).state);
id(thermostat).set_kd(id(thermostat_kd).state);
min_version: 2025.2.2
build_path: build/olimex-server-cabinet
friendly_name: ''
area: ''
platformio_options: {}
includes: []
libraries: []
name_add_mac_suffix: false
esp32:
board: esp32-evb
framework:
version: 2.0.5
advanced:
ignore_efuse_custom_mac: false
source: ~3.20005.0
platform_version: platformio/[email protected]
type: arduino
flash_size: 4MB
variant: ESP32
logger:
baud_rate: 115200
tx_buffer_size: 512
deassert_rts_dtr: false
hardware_uart: UART0
level: DEBUG
logs: {}
ota:
- platform: esphome
password: !secret 'ota_password'
version: 2
port: 3232
button:
- platform: shutdown
name: Server Cabinet Shutdown
disabled_by_default: true
icon: mdi:power
entity_category: config
- platform: restart
name: Server Cabinet Restart
disabled_by_default: false
icon: mdi:restart
device_class: restart
- platform: safe_mode
name: Server Cabinet Restart (Safe Mode)
icon: mdi:restart-alert
name: Server Cabinet Thermostat Autotune
icon: mdi:car-cruise-control
on_press:
- then:
- script.execute:
api:
encryption:
key: !secret 'api_encryption'
port: 6053
password: ''
reboot_timeout: 15min
http_request:
useragent: olimex-server-cabinet/2025.3.4-1 (Olimex EVB; olimex; evb) ESPHome/2025.2.2
timeout: 10s
verify_ssl: false
follow_redirects: true
redirect_limit: 3
binary_sensor:
- platform: status
name: Server Cabinet Status
entity_category: diagnostic
device_class: connectivity
name: Server Cabinet Ready
device_class: running
name: Server Cabinet Overheat
device_class: heat
lambda: !lambda |-
if (std::isnan(id(thermostat).current_temperature))
return {};
else if (id(thermostat).current_temperature > id(temperature_max))
return true;
else
return false;
name: Server Cabinet Underheat
device_class: cold
lambda: !lambda |-
return {};
else if (id(thermostat).current_temperature < id(temperature_min))
return true;
else
return false;
text_sensor:
- platform: version
name: Server Cabinet ESPHome Version
hide_timestamp: true
icon: mdi:application-import
web_server:
version: 2
port: !secret 'server_port'
auth:
username: !secret 'server_name'
password: !secret 'server_pass'
include_internal: true
ota: true
enable_private_network_access: true
log: true
css_url: ''
js_url: https://oi.esphome.io/v2/www.js
ethernet:
mdc_pin: 23
mdio_pin: 18
clk_mode: GPIO0_IN
domain: !secret 'wifi_domain_name'
phy_addr: 0
type: LAN8720
globals:
- id: temperature_min
type: float
restore_value: false
initial_value: '20'
- id: temperature_max
initial_value: '35'
type: float
time:
- platform: sntp
on_time:
- then:
- if:
condition:
switch.is_on:
then:
- script.execute:
else:
- logger.log:
tag: debug.script.pid.autotune
level: INFO
format: 'Ignoring request for scheduled autotuning: schedule not enabled'
args: []
seconds:
- 0
minutes:
- 0
hours:
- 0
days_of_month:
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
- 13
- 14
- 15
- 16
- 17
- 18
- 19
- 20
- 21
- 22
- 23
- 24
- 25
- 26
- 27
- 28
- 29
- 30
- 31
months:
- 1
- 2
- 3
- 4
- 5
- 6
- 7
- 8
- 9
- 10
- 11
- 12
days_of_week:
- 6
timezone: GMT0BST,M3.5.0/1,M10.5.0
update_interval: 15min
servers:
- 0.pool.ntp.org
- 1.pool.ntp.org
- 2.pool.ntp.org
switch:
name: Server Cabinet Thermostat Autotune Schedule
restore_mode: RESTORE_DEFAULT_ON
optimistic: true
icon: mdi:car-speed-limiter
assumed_state: false
number:
name: Server Cabinet Thermostat KP
unit_of_measurement: '%'
mode: BOX
initial_value: 0.9
step: 0.001
min_value: 0.0
max_value: 1.0
restore_value: true
optimistic: true
update_interval: 5s
icon: mdi:chart-bell-curve
set_action:
then:
id(thermostat).set_kp(x);
name: Server Cabinet Thermostat KI
initial_value: 0.00135
set_action:
then:
id(thermostat).set_ki(x);
mode: BOX
step: 0.001
min_value: 0.0
max_value: 1.0
restore_value: true
optimistic: true
update_interval: 5s
name: Server Cabinet Thermostat KD
initial_value: 0.0
max_value: 20.0
set_action:
then:
id(thermostat).set_kd(x);
mode: BOX
step: 0.001
min_value: 0.0
restore_value: true
optimistic: true
update_interval: 5s
output:
- platform: ledc
pin:
number: 2
allow_other_uses: true
mode:
output: true
input: false
open_drain: false
pullup: false
pulldown: false
inverted: false
ignore_pin_validation_error: false
ignore_strapping_warning: false
drive_strength: 20.0
frequency: 25000.0
min_power: 0.05
max_power: 1.0
zero_means_zero: true
climate:
- platform: pid
sensor: temperature
cool_output: output_cool
default_target_temperature: 27.5
visual:
min_temperature: 20.0
max_temperature: 35.0
control_parameters:
kp: 0.9
ki: 0.00135
kd: 0.0
starting_integral_term: 0.0
min_integral: -1.0
max_integral: 1.0
derivative_averaging_samples: 1
output_averaging_samples: 1
on_state:
- then:
- if:
condition:
binary_sensor.is_on:
then:
- number.set:
value: !lambda |-
return id(thermostat).get_kp();
- number.set:
value: !lambda |-
return id(thermostat).get_ki();
- number.set:
value: !lambda |-
return id(thermostat).get_kd();
bool actv_thermo = id(thermostat).mode != 0;
bool actv_fan = id(fan_control).state != 0;
if (actv_thermo != actv_fan) {
auto call = (actv_thermo) ? id(fan_control).turn_on() : id(fan_control).turn_off();
call.perform();
fan:
- platform: binary
name: Server Cabinet Fan
output: output_cool
on_turn_on:
- then:
- if:
then:
- climate.control:
mode: COOL
condition:
on_turn_off:
- then:
- if:
then:
- climate.control:
mode: 'OFF'
condition:
- platform: pulse_counter
name: Server Cabinet Fan Speed
pin:
number: 5
mode:
input: true
pullup: true
output: false
open_drain: false
pulldown: false
inverted: false
state_class: measurement
unit_of_measurement: RPM
accuracy_decimals: 0
update_interval: 1s
filters:
- multiply: 0.5
- exponential_moving_average:
alpha: 0.15
send_every: 1
send_first_at: 1
- or:
- delta:
value: 5.0
type: absolute
- heartbeat: 60s
icon: mdi:fan-clock
force_update: false
count_mode:
rising_edge: INCREMENT
falling_edge: DISABLE
use_pcnt: true
internal_filter: 13us
- platform: duty_cycle
name: Server Cabinet Fan Duty
pin:
number: 2
mode:
input: true
output: false
open_drain: false
pullup: false
pulldown: false
inverted: false
update_interval: 1s
icon: mdi:gauge
force_update: false
- platform: pid
name: Server Cabinet Thermostat P Term
climate_id: thermostat
type: PROPORTIONAL
force_update: false
icon: mdi:gauge
accuracy_decimals: 1
- platform: pid
name: Server Cabinet Thermostat I Term
type: INTEGRAL
force_update: false
icon: mdi:gauge
- platform: pid
name: Server Cabinet Thermostat D Term
type: DERIVATIVE
force_update: false
icon: mdi:gauge
- platform: pid
name: Server Cabinet Thermostat Result
type: RESULT
icon: mdi:arrow-collapse-vertical
force_update: false
- platform: pid
name: Server Cabinet Thermostat Error
type: ERROR
filters:
- multiply: -1.0
icon: mdi:sun-snowflake
force_update: false
- platform: am2320
i2c_id: climate_upper
address: 0x5C
update_interval: 5s
setup_priority: -100.0
temperature:
name: Server Cabinet Upper Temperature
force_update: false
unit_of_measurement: °C
device_class: temperature
humidity:
name: Server Cabinet Upper Humidity
force_update: false
device_class: humidity
- platform: am2320
i2c_id: climate_lower
address: 0x5C
update_interval: 5s
temperature:
name: Server Cabinet Lower Temperature
force_update: false
humidity:
name: Server Cabinet Lower Humidity
force_update: false
name: Server Cabinet Center Temperature
update_interval: 5s
setup_priority: -400.0
lambda: !lambda |-
float sum = 0;
uint16_t cnt = 0;
if (!std::isnan(id(climate_upper__temperature).state)) {
sum += id(climate_upper__temperature).state;
cnt += 1;
if (!std::isnan(id(climate_lower__temperature).state)) {
sum += id(climate_lower__temperature).state;
cnt += 1;
if (cnt == 0) {
return NAN;
} else {
return ((sum / cnt) * 1.15);
force_update: false
name: Server Cabinet Center Humidity
lambda: !lambda |-
float sum = 0;
uint16_t cnt = 0;
if (!std::isnan(id(climate_upper__humidity).state)) {
sum += id(climate_upper__humidity).state;
cnt += 1;
if (!std::isnan(id(climate_lower__humidity).state)) {
sum += id(climate_lower__humidity).state;
cnt += 1;
if (cnt == 0) {
return NAN;
} else {
return ((sum / cnt) * 0.85);
update_interval: 5s
force_update: false
name: Server Cabinet Temperature
setup_priority: -500.0
filters:
alpha: 0.075
send_every: 1
send_first_at: 1
lambda: !lambda |-
float sum = 0;
uint16_t cnt = 0;
cnt += 1;
if (!std::isnan(id(climate_center__temperature).state)) {
sum += id(climate_center__temperature).state;
cnt += 1;
cnt += 1;
if (cnt == 0) {
return NAN;
} else {
return (sum / cnt);
update_interval: 5s
force_update: false
name: Server Cabinet Humidity
filters:
alpha: 0.075
send_every: 1
send_first_at: 1
lambda: !lambda |-
float sum = 0;
uint16_t cnt = 0;
cnt += 1;
if (!std::isnan(id(climate_center__humidity).state)) {
sum += id(climate_center__humidity).state;
cnt += 1;
cnt += 1;
if (cnt == 0) {
return NAN;
} else {
return (sum / cnt);
update_interval: 5s
force_update: false
script:
- id: autotune
then:
- logger.log:
format: Starting autotuning process…
level: INFO
args: []
- climate.pid.autotune:
positive_output: 1.0
noiseband: 0.25
negative_output: -1.0
mode: single
parameters: {}
i2c:
- scl: 16
sda: 13
scan: false
frequency: 50000.0
- scl: 1
sda: 3
scan: false
frequency: 50000.0
