Hi, I’ve tried it, and I am having trouble with it, can anybody here confirm that they have pwm servo control output working via ESPhome on a ESP8266 module of any type ?
(if so the code you use would be great to see).
Cheers,
Martin
Looks like I’m perhaps on my own with ESPhome and PWM servo control projects…
This is what I’m trying to use below. If I remove the Servo references it connects to WiFi and HA fine, if I add back the Servo references the NodeMCU will not connect to the router anymore. Reverting to the version without Servo then will connect as it did before. In the case of the full version that won’t connect, it will drive a servo when triggered by GPIO, so the servo code works, just breaks WiFi.
Clues anybody, I’ve tried two NodeMCU’s and also different pin combinations, fast and normal connect ?
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: !secret wifi_ssid
fast_connect: true
# Enable logging
# Enable logging
logger:
level: VERBOSE
# Enable Home Assistant API
api:
ota:
servo:
- id: my_servo
output: pwm_output
output:
- platform: gpio
pin: D1
inverted: False
- platform: esp8266_pwm
pin: D7
frequency: 50 Hz
binary_sensor:
- platform: gpio
pin: D8
device_class: motion
on_press:
then:
- output.turn_on: gpio_d1_led
- servo.write:
level: 100.0%
on_release:
then:
- output.turn_off: gpio_d1_led
- servo.write:
level: -100.0%
try hitting up Otto on the Discord chat
I’ve tried via the Github issues path.
I really just need to find somebody who’s used the Servo component in a real project to know it works for somebody else.
Definitely try Discord, Otto (creator of ESPhome) is on there a fair bit and will be able to explain it. In saying that, I’d be keen to see you get it sorted too as this is something I may try one day
Have you got a link to the Discord you talk to him on ?
Just spent quite some time researching what Discord is, and installing/joining up to it, but I can’t locate his chat or directions to find it…
This config is working for me, except I had to use -50% to +50% range
Are you sure the wifi settings is the guilty here? In my case when enabling wifi the servo does some tiny glitches (chatting) which might be due the esp cannot set a pwm output steady (this is a know limitation of esp8266)
Try setting the range to +10% and -10% and if it works increase them until you find the limits.
Thanks for ideas, will try here in a few days (on the road now).
What happened when you tried ±100% out of interest.
True, I’m not sure if WiFi settings are an issue, but I tried different connect speed, static IP etc. If I remove Servo then it connects in every WiFi setting.
The servo shuts off. It moves nowhere, and you can move the horn with your hand.
Try using another pin, D5, D6 or D8
I think the ESP8266 is PWM only on these pins.
My test analogue RC servo works fine on my NodeMCU V3, at +/-100% throw, with no chattering. I was very pleased how it drives the servo actually.
What dies is WiFi, once I include that code, no longer connects to Wifi, but servo responds to a GPIO button on the NodeMCU…
I have a ESP32 board arrived, I’m going to try the same code on that.
After far too much faffing around with my two misbehaving cheap ESP8266 NodeMCU’s with the ESPhome Servo component without success, I now have full success driving the RC servo with an ESP32 NodeMCU instead.
I don’t know what’s wrong with these two ESP8266 NodeMCU’s I had (and I don’t care now) but the same servo, same AM312 motion sensor and same 5V power supply and cables works fine on the new ESP32 (which is a cheap ESP-WROOM-32 from Ebay).
As the ESP32 is not supported for the Servo component (apparently the libraries don’t exist yet AFAIK) I used the ESP32 LEDC output component.
esphome:
platform: ESP32
board: esp32doit-devkit-v1
wifi:
fast_connect: false
# Enable logging
logger:
level: VERBOSE
api:
ota:
- platform: wifi_signal
name: "Servo actuator #1 WiFi Signal Sensor"
update_interval: 60s
binary_sensor:
- platform: status
name: "Servo actuator #1 Status"
- platform: gpio
pin: GPIO23
name: "Servo actuator #1 Motion"
on_press:
then:
- output.turn_on: triggered_led
- output.set_level:
level: 100.0% # 100% = 2mS as set by 'max_power'
on_release:
then:
- output.turn_off: triggered_led
- output.set_level:
level: 0.0% # 0% = 1mS as set by 'min_power'
# Using Light component to set a standard RC servo position
light:
- platform: monochromatic
output: gpio_21_servo
name: "Servo actuator #1 - Servo Pos"
default_transition_length: 0ms
# Using ledc output to control a standard 50Hz RC servo over the normal 1 to 2 mS pulse range
output:
- platform: ledc
pin: GPIO21
frequency: 50 Hz
min_power: 5.0% # 5% at 50Hz is 1mS (20mS cycles)
max_power: 10.0% # 10% at 50Hz is 2mS (20mS cycles)
- platform: gpio
pin: GPIO22
inverted: False
The servo control in HA appears as a light of course…
This should be translated to a feature request in esphome feature tracker. I mean to support servo in esp32. Would you add it?
i want to make the same with an ESP32-cam but it doesnt work… :
platform: ESP32
board: esp-wrover-kit
wifi:
ssid: "xxxxxxxxx"
password: "xxxxxxxxxxxxxx"
manual_ip:
static_ip: 192.168.1.48
gateway: 192.168.1.1
subnet: 255.255.255.0
# Enable logging
logger:
api:
password: "xxxxxxxxxxxx"
ota:
password: "xxxxxxxxx"
# ESP32-CAM
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
vertical_flip: false
horizontal_mirror: false
resolution: 640x480
# ... Frame Settings
name: "WiFi Signal garage_motor"
binary_sensor:
- platform: status
name: "ServoRotate actuator Status"
on_press:
then:
- output.set_level:
on_release:
then:
- output.set_level:
switch:
- platform: restart
name: "Restart Cam garage_motor"
output:
# Flashlight
- platform: gpio
pin: GPIO4
# Servo Rotate : Using ledc output to control a standard 50Hz RC servo over the normal 1 to 2 mS pulse range
- platform: ledc
pin: GPIO13
frequency: 50 Hz
# Flashlight
light:
- platform: binary
output: gpio_4
output: gpio_13_servoR
name: "ServoRotate Position"
If someone can help, i will appreciate
thanks
Olivier
Oliver, I’m a newbie also but can try help, but could you edit and repost the YAML in the same style format as it is in ESPhome, with the back-tick method, it’s going to be easier to read ?
Place three ‘back ticks’ a line before and line after you paste the YAML…
(back tick ` is the character under the ‘tilde’ ~ on the top LHS of a US keyboard)
What errors are you getting? What do the EspHome logs say?
@mr.sneezy r.sneezy
thanks i dont know how to do it lol…i have modify
@ OttoWinter said “ledc” output might be used by internals on ESP32-CAM, its not like a “ordinary” ESP32…
thanks @Drew.B @mr.sneezy
no error, no logs, the image of the cam no longer works…as i said just up : OttoWinter said “ledc” output might be used by internals on ESP32-CAM, its not like a “ordinary” ESP32…
i have try another way : use a esp8266 to control tilt and yaw and try this exemple :
but now my hassio stucks and fail to login to lovelace page…
here is my config esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "xxxxxx"
password: "xxxxxxxxxxx"
manual_ip:
static_ip: 192.168.1.46
# Enable logging
logger:
api:
services:
- service: control_servo
variables:
level: float
then:
- servo.write:
level: !lambda 'return level / 100.0;'
ota:
i2c:
sda: D2
scl: D1
scan: True
binary_sensor:
- platform: status
- platform: bmp085
pressure:
name: "Pression Atmospherique Garage"
- platform: dht
pin: GPIO14
temperature:
humidity:
model: DHT22
switch:
- platform: restart
name: "Restart Capteur Garage"
output:
- platform: gpio
pin:
number: GPIO0
mode: OUTPUT_OPEN_DRAIN
inverted: yes
# PinPwm configuration entry servo rotate
pin: GPIO02
frequency: 50 Hz
fan:
- platform: binary
output: relaisg
servo:
- id: servoR
output: pwm_out_ServoR
config input_number: (yaml dont exist, i create one)
servoR_control:
name: Servo Rotate Control
initial: 0
min: -100
max: 100
step: 1
mode: slider
automation :
automation:
- alias: Write Servo Value to ESP
platform: state
entity_id: input_number.servoR_control
# Replace livingroom with the name you gave the ESP
- service: esphome.capteur_garage_control_servo
data_template:
level: '{{ trigger.to_state.state | int }}'
after that the server is only accessible by samba file in explorer…no more login possible.
Sure there is something wrong in one or more of thoses files…
I search…lol
If you see something…thanks!
Oliver you may well need to try a standard ESP32 module first, rather than the ESP32-CAM module like Otto suggested. The camera code may use up peripherals or ram that is needed by LEDC.
Also, the esp8266_pwm component ONLY applies to the ESP8266, does not run yet on the ESP32’s.
When this stuff happens to me I try strip back the project code to only the problem part, and hack at it till that bit is fixed, then introduce back the other parts around it.
