Is there a way, that not only the entity-parameter from Python scripts are shown in service-call UI in automations, scripts and developer tools, but others as well?
E.g. from the example
# turn_on_light.py
entity_id = data.get("entity_id")
rgb_color = data.get("rgb_color", [255, 255, 255])
if entity_id is not None:
service_data = {"entity_id": entity_id, "rgb_color": rgb_color, "brightness": 255}
hass.services.call("light", "turn_on", service_data, False)
with services.yaml
turn_on_light:
name: Turn on light
description: Turn on a specific light and set its color.
fields:
entity_id:
description: The light that will be turned on.
example: light.bedroom
rgb_color:
description: The color to which the light will be set.
example: [255, 0, 0]
Then only for entity_id there is a input box, but not for rgb_color:
I expected that every parameter (and they are shown below in the description) provide then an UI-Input field, like in other services.
Something I do wrong or not (yet) support or how I can do this in another declaration in script and/(or services.yaml to have the other parameter as well?
