On my last few upgrades (most recently 0.72.0 to 0.73.0), I’ve been seeing this:
pyowm 2.8.0 has requirement requests<2.19,>=2.18.2, but you'll have requests 2.19.1 which is incompatible.
The upgrade complates, and I can’t see any obvious problems. Just wondering what this means and whether it’s something I (or anyone) should be concerned about)
I tried forcing requests back to the earlier version with:
pip install requests==2.19
But the next “pip3 install --upgrade homeassistant” brought it back to 2.19.1 (and with the same error about incompatible versions)
I should have mentioned the platform. It’s not exactly Hassbian, but probably close enough. I’m using a stock version of Raspbian stretch with HA installed in virtual environment. I gather that the issue is related to running on Raspbian/Hassbian??
I upgraded to 0.76.2 today and I’m no longer seeing the error (possibly it was fixed in some earlier version and I just didn’t notice until now). I sse that it’s using pyowm 2.9.0 which is probably what did it.
