🎬 PYScript Smart Plex Launcher Ai Task
:clapper_board: PYScript Smart Plex Launcher
Description:
This script uses Ai Task to automatically scan libraries and their content, manage devices and media players, search for, and play media content in the specific zone/room requested.
The script acts as an intelligent driver: it converts a voice command into a complex JSON request for the Plex API, automatically correcting speech recognition errors (grammar, endings).
Features:
  • Playback Commands: Supports “Play” (from the beginning) and “Resume” (Smart Resume — from the paused point or the next episode).
  • Smart Search: Searches by title, season, episode, album, song, playlist, year, genre, artist, actor, director, studio, music videos, and even mood.
  • Scenarios: Distinguishes between requests like “Play fresh” (newest items without shuffling) and “Play anything” (shuffle/random).
  • Autonomy: Automatically determines Plex Library IDs (Auto-Discovery) and caches the database for instant response.
  • Hardware Control: Turns on TV/Set-top Box (Apple TV, WebOS, Tizen) and launches the Plex app in the required zone.
:gear: Requirements
The following components are required for operation:
  1. Plex Media Server: Installed and configured.
  2. Home Assistant:
  • Plex Media Server Integration.
  • Pyscript Integration.
  • Configured Voice Assistant (Assist) with a connected AI (Ollama / Google Gemini).
:rocket: Installation and Setup
Step 1. Install Pyscript
  1. Place the plex_smart_launch.py script file into the /config/pyscript/ folder.
  2. Edit the SETTINGS section in the file:
  • PLEX_URL: Server address.
  • PLEX_TOKEN: Authorization token.
How to get the token: In the Plex Server web interface (not HA), click the three dots on any media item → Get InfoView XML. The token is located at the very end of the URL in the address bar.
  • ZONES: Define your devices.
  1. Reload Pyscript.
Step 2. Create the Bridge
To communicate between the script and the Voice Assistant, an intermediate script is needed.
Create a new script in Home Assistant (Settings → Automations & Scenes → Scripts → Add Script) and paste this YAML code:
Do not forget to give the AI access to this script in the Assistant settings!
alias: Smart Plex Bridge
description: Bridge to transfer commands from AI to Pyscript
fields:
  command_text:
    example: play movie Avatar
sequence:
  - action: pyscript.plex_smart_launch
      command_text: "{{ command_text }}"
  - stop: Success
mode: single
Step 3. Instructions for the Dialogue System (AI Prompt)
Add this text to the system instructions (System Prompt) of your AI (Ollama / Gemini) in Home Assistant:
GENERAL RULES (PLEX):
1. When the user asks to play a movie/series/music, you MUST SILENTLY and IMMEDIATELY call the tool `script.smart_plex_bridge`.
2. Pass the full user phrase into the `command_text` parameter without changes.
3. Wait for the tool response (it will return "Success").
4. ONLY AFTER THAT, output the final phrase: "Sir, searching and launching. I am at your service."
5. NEVER answer anything else. Do not write any text before calling the tool.
:speaking_head: Testing Functionality via Developer Tools:
In Developer Tools, go to the Actions tab (in YAML mode or UI mode):
  • Find pyscript.plex_smart_launch in the Action field.
  • Use the following commands in the Data field:
1.) Simple Movie Launch
command_text: play movie The Gentlemen
2.) Smart Resume (Continue watching)
command_text: resume TV show House M.D.
3.) Precise Episode Launch
command_text: play season 3 episode 5 Rick and Morty
4.) Music Videos
command_text: play clips Rammstein (Videos might not work but songs will play)
5.) Fresh Releases (Sorted by date)
command_text: play fresh sci-fi
6.) Search by Mood
command_text: play happy music
7.) Search by Actor
command_text: play movie with Brad Pitt
8.) Random Choice (Shuffle)
command_text: play any comedy
9.) Search by Year
command_text: play action movie 2024
10.) Music Album
command_text: play Linkin Park album Meteora
import json
import aiohttp
import random
import xml.etree.ElementTree as ET
from difflib import SequenceMatcher
# SCRIPT: plex_smart_launch
# VERSION: v5.4
# CHANGES:
#   - FIX: Client scanning is now done in a loop.
#          The script waits up to 30 seconds for the player to appear,
#          pressing Scan every 3 seconds.
# === 1. SETTINGS === Replace with your own values
PLEX_URL = "https://[plex_server_ip]:32400"        # Specify Plex Server IP and Port
PLEX_TOKEN = "XyZ987PvQgRtLmNoKjHs"                # Insert your Plex Token
PLEX_SCAN_BUTTON = "button.plex_190_scan_clients"  # Scan Clients Button (Find in HA Plex Integration)
VERIFY_SSL = False
AI_ENTITY_ID = "ai_task.google_ai_task"            # Specify your Ai Task entity
# Cache (No editing/configuration needed)
PLEX_LIBS = {}
PLEX_CACHE = {"movie": [], "show": [], "music": []}
# === 2. ZONES === Specify your entity IDs and Zone names (living_room, guest_room, bedroom)
ZONES = {
    "living_room": {
        "plex_client": "media_player.plex_plex_for_apple_tv_apple_tv",
        "plex_device_id": "2d3845d406074601d143cf77ac3299ae",
        "hardware_device_id": "84971b66f2f787bd9d999e9edd1f3d6a",
        "hardware_entity": "media_player.apple_tv_4k",
        "power_method": "apple_tv_device",   # Do not edit or replace in code below
        "boot_delay": 2, "app_load_delay": 6 # Time required to start TV and Plex App
    "guest_room": {
        "plex_client": "media_player.plex_plex_for_lg_lg_oled42c2rlb",
        "hardware_device_id": "d025f3fd72c4d87b35bbda8128644844",
        "hardware_entity": "media_player.lg_webos_tv_oled42c2rlb",
        "power_method": "lg_device",          # Do not edit or replace in code below
        "boot_delay": 6, "app_load_delay": 12
    "bedroom": {
        "plex_client": "media_player.plex_plex_for_samsung_tv_2019",
        "plex_device_id": "fc42e34c5ed19fff35f5e2ac4b4f55cc",
        "remote_entity": "remote.samsung_the_frame_49_qe49ls03rauxru",
        "hardware_entity": "media_player.samsung_the_frame_49_qe49ls03rauxru",
        "power_method": "samsung_remote",     # Do not edit or replace in code below
        "boot_delay": 6, "app_load_delay": 15
# ======== End of Settings, Only the Prompt can be edited below ========
# === 3. AUTO-DISCOVERY OF LIBRARIES & CACHE ===
async def update_plex_cache():
    global PLEX_CACHE, PLEX_LIBS
    conn = aiohttp.TCPConnector(ssl=VERIFY_SSL)
    async with aiohttp.ClientSession(connector=conn) as session:
        try:
            url_libs = f"{PLEX_URL}/library/sections?X-Plex-Token={PLEX_TOKEN}"
            async with session.get(url_libs) as resp:
                if resp.status == 200:
                    root = ET.fromstring(await resp.text())
                    for directory in root.findall(".//Directory"):
                        l_type = directory.get("type")
                        if l_type == "artist": l_type = "music"
                        if l_type in ["movie", "show", "music"]:
                            PLEX_LIBS[l_type] = {"id": directory.get("key"), "title": directory.get("title")}
        except: return
        for l_type, lib_info in PLEX_LIBS.items():
            try:
                url = f"{PLEX_URL}/library/sections/{lib_info['id']}/all?X-Plex-Token={PLEX_TOKEN}"
                async with session.get(url) as resp:
                        xml_data = await resp.text()
                        root = ET.fromstring(xml_data)
                        items = []
                        if l_type == "movie":
                            for node in root.findall(".//Video"):
                                items.append({"title": node.get("title", "").lower(), "orig": node.get("originalTitle", "").lower(), "year": node.get("year"), "id": node.get("ratingKey")})
                        elif l_type in ["show", "music"]:
                            for node in root.findall(".//Directory"):
                                items.append({"title": node.get("title", "").lower(), "orig": node.get("originalTitle", "").lower(), "id": node.get("ratingKey")})
                        PLEX_CACHE[l_type] = items
            except: pass
def find_in_cache(target_type, query_string):
    lib = PLEX_CACHE.get(target_type, [])
    if not lib or not query_string: return None
    q = query_string.lower().strip()
    best, highest = None, 0.0
    for item in lib:
        r = max(SequenceMatcher(None, q, item["title"]).ratio(), SequenceMatcher(None, q, item.get("orig", "")).ratio())
        if r > 0.95: return item
        if r > 0.6 and r > highest: highest = r; best = item
    return best
# === 4. HARDWARE (HABR STYLE SCAN) ===
async def boot_hardware_process(zone_config):
    hw_entity = zone_config.get("hardware_entity")
    plex_client = zone_config["plex_client"]
    power = zone_config.get("power_method")
    # 1. Turn on TV/Set-top box
    if power == "apple_tv_device":
        await service.call("media_player", "turn_on", device_id=zone_config["hardware_device_id"])
    elif power == "lg_device":
        if state.get(hw_entity) in ["off", "unavailable"]:
    elif power == "samsung_remote":
        await service.call("remote", "turn_on", entity_id=zone_config["remote_entity"])
    else:
        await service.call("media_player", "turn_on", entity_id=hw_entity)
    await task.sleep(zone_config["boot_delay"])
    # 2. Launch Plex (if needed)
    try:
        if power == "apple_tv_device" or state.getattr(hw_entity).get("source") != "Plex":
             await service.call("media_player", "select_source", entity_id=hw_entity, source="Plex")
             await task.sleep(zone_config["app_load_delay"])
    except: pass
    # 3. SCANNING LOOP (Habr Style)
    # Try 10 times with a 3-second pause (30 sec total) until the client becomes available
    for i in range(10):
        # If client appears (not unavailable/unknown/off) — exit loop
        current_state = state.get(plex_client)
        if current_state not in ["unavailable", "unknown", "off"]:
            log.debug(f"Plex Client found: {plex_client} (State: {current_state})")
            break
        # If not found — press Scan
        log.debug(f"Plex Client not found. Scanning... (Attempt {i+1}/10)")
        try: await service.call("button", "press", entity_id=PLEX_SCAN_BUTTON)
        except: pass
        await task.sleep(3)
# === 5. LOGIC ===
@service
def plex_smart_launch(command_text=None):
    if not command_text: return
    task.create(smartplex_execution, cmd=command_text)
async def smartplex_execution(cmd):
    if not PLEX_LIBS: await update_plex_cache()
    # === PROMPT ===
    prompt = (
        "You are SmartPlex, a Plex API driver. Output JSON only.\n"
        "CLEANUP: Remove '4k', 'uhd', 'imax', 'hdr' from title.\n\n"
        "1. HARD SCENARIOS (PRIORITY):\n"
        "- 'fresh', 'new', 'latest' -> sort_order='newest', shuffle=false, year=2024 (do not leave year empty).\n"
        "- 'old', 'classic', 'early' -> sort_order='oldest', year=2000 (approximate limit).\n"
        "- 'best', 'top', 'popular' -> sort_order='top_rated'.\n"
        "- 'Any', 'Random', 'Something' -> sort_order='random', shuffle=true.\n"
        "- 'Linkin Park 2023' (Music + Year) -> {artist: 'Linkin Park', year: 2023}.\n\n"
        "2. LANGUAGE RULES:\n"
        "- Genres MUST be in English: 'Comedy', 'Action', 'Drama', 'Sci-Fi'.\n"
        "- Use standard Plex genre names.\n\n"
        "3. ZONES (room):\n"
        "- 'living room', 'hall', 'main room' -> 'living_room'\n"
        "- 'guest room', 'kids room', 'small room' -> 'guest_room'\n"
        "- 'bedroom', 'bed' -> 'bedroom'\n\n"
        "4. TYPES (type):\n"
        "- 'movie': Movies.\n"
        "- 'show': TV Shows / Series.\n"
        "- 'music': Music.\n"
        "- 'music_video': Music Videos / Clips.\n"
        "- 'playlist': Playlists.\n\n"
        "5. QUERY FILLING RULES:\n"
        "--- MOVIE ---\n"
        "   * ALLOWED: title, year, genre, actor, director, studio, collection, country, decade, contentRating.\n"
        "--- SHOW ---\n"
        "   * ALLOWED: show_name, season, episode, genre, year, studio.\n"
        "--- MUSIC ---\n"
        "   * ALLOWED: artist, album, title, year, genre, mood.\n"
        "--- MUSIC_VIDEO ---\n"
        "   * ALLOWED: artist.\n\n"
        "6. CONTROLS (control):\n"
        "- resume_mode: 'resume' (continue, finish, resume), 'start' (play, watch, start). DEFAULT: 'start'.\n"
        "- sort_order: 'newest', 'oldest', 'top_rated', 'random', 'default'.\n"
        "- shuffle: true (if 'shuffle', 'mix' or request is generic).\n\n"
        "JSON OUTPUT:\n"
        "{\n"
        "  \"control\": { \"room\": \"...\", \"type\": \"...\", \"resume_mode\": \"start/resume\", \"sort_order\": \"...\", \"shuffle\": false },\n"
        "  \"query\": { \"title\": \"...\", \"show_name\": \"...\", \"artist\": \"...\", \"album\": \"...\", \"season\": null, \"episode\": null, \"actor\": \"...\", \"genre\": \"...\", \"year\": null, \"studio\": \"...\", \"collection\": \"...\", \"decade\": null, \"contentRating\": \"...\", \"mood\": \"...\" }\n"
        "}\n"
        f"USER COMMAND: {cmd}"
    try:
        response = await service.call("ai_task", "generate_data",
                                      entity_id=AI_ENTITY_ID,
                                      task_name="SmartPlex",
                                      instructions=prompt, return_response=True)
        data = json.loads(response.get('data', '').replace('```json', '').replace('```', '').strip())
        control = data.get("control", {})
        query = data.get("query", {})
        room_key = control.get("room", "living_room")
        if room_key not in ZONES: room_key = "living_room"
        zone = ZONES[room_key]
        hw_task = task.create(boot_hardware_process(zone))
        payload = {"allow_multiple": 1}
        m_type = control.get("type", "movie")
        if control.get("resume_mode") == "resume": payload["resume"] = 1
        else: payload["resume"] = 0; payload["offset"] = 0
        sort_mode = control.get("sort_order", "default")
        if sort_mode == "newest":
            payload["sort"] = "originallyAvailableAt:desc"
            payload["shuffle"] = 0
        elif sort_mode == "oldest":
            payload["sort"] = "originallyAvailableAt:asc"
        elif sort_mode == "top_rated":
            payload["sort"] = "audienceRating:desc"
        elif control.get("shuffle") or sort_mode == "random":
            payload["shuffle"] = 1
        media_type = "MOVIE"
        # >>> SHOWS
        if m_type == "show":
            media_type = "EPISODE"
            lib_data = PLEX_LIBS.get("show")
            if lib_data: payload["library_name"] = lib_data["title"]
            s_name = query.get("show_name") or query.get("title")
            cached = find_in_cache("show", s_name)
            exact_episode = query.get("episode")
            if cached:
                if exact_episode: payload["show.id"] = cached["id"]
                else: payload["show.title"] = cached["title"]
            else:
                if s_name: payload["show.title"] = s_name
            if query.get("season"): payload["season.index"] = int(query["season"])
            if query.get("episode"): payload["episode.index"] = int(query["episode"])
            if not exact_episode and control.get("resume_mode") == "resume":
                payload["episode.unwatched"] = 1
        # >>> MUSIC
        elif m_type == "music":
            media_type = "MUSIC"
            lib_data = PLEX_LIBS.get("music")
            artist = query.get("artist")
            cached = find_in_cache("music", artist)
            filter_active = query.get("year") or query.get("album") or query.get("title") or query.get("genre") or query.get("mood")
            if cached and not filter_active:
                payload["id"] = cached["id"]
            else:
                if artist: payload["artist.title"] = artist
                if query.get("album"): payload["album.title"] = query["album"]
                if query.get("title"): payload["track.title"] = query["title"]
                if query.get("genre"): payload["genre"] = query["genre"]
                if query.get("mood"): payload["mood"] = query["mood"]
            if query.get("year"): payload["year"] = int(query["year"])
        # >>> MUSIC VIDEOS
        elif m_type == "music_video":
            if cached:
            elif artist:
        # >>> MOVIES
        elif m_type == "movie":
            lib_data = PLEX_LIBS.get("movie")
            f_title = query.get("title")
            has_filters = query.get("actor") or query.get("genre") or query.get("studio") or query.get("collection") or query.get("decade")
            if f_title and not has_filters:
                cached = find_in_cache("movie", f_title)
                if cached: payload["id"] = cached["id"]
                else: payload["title"] = f_title
            else:
                if f_title: payload["title"] = f_title
                if query.get("actor"): payload["actor"] = query["actor"]
                if query.get("director"): payload["director"] = query["director"]
                if query.get("unwatched"): payload["unwatched"] = 1
                if query.get("studio"): payload["studio"] = query["studio"]
                if query.get("collection"): payload["collection"] = query["collection"]
                if query.get("country"): payload["country"] = query["country"]
                if query.get("contentRating"): payload["contentRating"] = query["contentRating"]
                if query.get("decade"): payload["decade"] = int(query["decade"])
        # >>> PLAYLISTS
        elif m_type == "playlist":
            media_type = "PLAYLIST"
            p_title = query.get("title")
            await hw_task
            target_dev = zone.get("plex_device_id")
            target_ent = zone.get("plex_client")
            await service.call("media_player", "play_media",
                               device_id=target_dev, entity_id=target_ent,
                               media_content_id=json.dumps({"playlist_name": p_title, "shuffle": 1}),
                               media_content_type="PLAYLIST")
            return
        # 3. FINAL EXECUTION
        await hw_task
        log.debug(f"SmartPlex Payload: {payload}")
        target_ent = zone.get("plex_client") if not target_dev else None
                           media_content_id=json.dumps(payload),
                           media_content_type=media_type)
    except Exception as e:
        log.error(f"SmartPlex Error: {e}")
@time_trigger('startup')
@time_trigger('cron(0 * * * *)')
async def cron_cache():
how do i get the "zones" information?
i found this link and it seems like it might be helpful, but i dont know what info to grab:
https://plex.tv/devices.xml
Hi @jasperwill!
Actually, "zones" in this script simply refer to the physical rooms or spaces in your house (like living_room, guest_room, or bedroom). They are entirely independent and have nothing to do with Plex settings, so you don't need to look for them in plex.tv/devices.xml.
The ZONES section is just a logical mapping for Home Assistant. It links a simple room name (so the AI understands when you say "play a movie in the living room") to your local Home Assistant entities.
To fill out the "zones" information, you just need to look inside your Home Assistant:
  1. Go to Developer Tools -> States.
  2. Find the entity_id for your TV (hardware) and the entity_id for the Plex client in that specific room.
  3. Paste those Home Assistant IDs into the corresponding room block in the script.
You make up the zones yourself based on how your smart home is physically laid out!
