Pyscript - task.executor of module
I have the following script called edit_myhouse_theme.py in the config/pyscripts folder:
import fileinput
import sys
import os
import time
@service
def changefilepyscript():
  if '/config/pyscript_modules' not in sys.path:
    sys.path.append('/config/pyscript_modules')
  path = '/config/themes/myhouse-mode/myhouse-mode.yaml'
  time.sleep(10)
  file_name = state.get('input_text.background_full_filename')
  task.executor(theme_module.changetheme, file_name)
The script was to replace the name of the lovelace_theme value in the theme file. As this involves open commands, there is a script in config/pyscript_modules called theme_module.py that i call using task.executor. This carries out the file changes. The code is below:
import fileinput
import sys
import os
def changetheme(file_selected=None):
    if len(file_selected) > 8:
      with open(path) as file:
        data = file.readlines()
      data[13] = f'  lovelace-background: "center / cover no-repeat url(\'local/images/backgrounds/{file_selected}\')"\n'
      with open(path, 'w') as file:
        file.writelines(data)
I have run the created pyscript service changefilepyscript and get the following error:
This error originated from a custom integration.
Logger: custom_components.pyscript.file.edit_myhouse_theme.changefilepyscript
Source: custom_components/pyscript/eval.py:510
integration: Pyscript Python scripting (documentation, issues)
First occurred: 13:45:10 (1 occurrences)
Last logged: 13:45:10
Exception in <file.edit_myhouse_theme.changefilepyscript> line 18: task.executor(theme_module.changetheme, file_name) ^ NameError: name 'theme_module.changetheme' is not defined
I am not sure what i have failed to do as i think i have set the module path up correctly in the calling pyscript but may be wrong. Any help appreciated
UPDATE:
I have moved on a bit by using @pyscript_compile rather than a 2nd native python script.
import fileinput
import sys
import os
import time
@service
#  if 'config/pyscript_modules' not in sys.path:
#    sys.path.append('config/pyscript_modules')
#  path = 'config/themes/myhouse-mode/myhouse-mode.yaml'
#  time.sleep(10)
  contents, exception = task.executor(changetheme, file_name)
  if exception:
      raise exception
  log.info(f"contents = {contents}")
@pyscript_compile
#    if len(file_selected) > 8:
   path = '/homeassistant/themes/myhouse-mode/myhouse-mode.yaml'
     with open(path, 'w') as filew:
       filew.writelines(data)
However, the path name for the yaml file is not finding the file even though i have used ssh to confirm and tried various variations on the name (config, homeassistant etc).
The current definition is
Readlink using the full python text above returns the same correct path so the format is at least correct.
I am at a total loss with this.
This path worked
path = '/config/themes/myhouse'
Full code for function is
def changetheme(file_selected):
  yamlfile = 'myhouse.yaml'
  with chdir(path):
    with open(yamlfile) as file:
      data[13] = f'  lovelace-background: "center / cover no-repeat url(\'local/images/backgrounds/{ file_selected }\')"\n'
