The PytesEbox component allows you to pull data from Pytes Batteries into ESPHome.
It uses UART for communication.
Hardware Setup
You can connect to Pytes E-Box using the port labeled Console
Any connections via CAN or RS485 (e.g. to an inverter) are untouched and remain functional.
The console port offers a RS232 interface using a RJ45 connector.
The voltage levels are not TTL-compatible. A RS232 transceive r must be placed between the Batteries and the ESPHome device. MAX3232 -based transceivers have been tested and work well.
If you have multiple batteries you need to connect to the master battery’s console port.
Hello. I am trying to install this on Pytes V5 battery but I can’t compile it. where do I put the “components” folder? “homeassistant/esphome/components/pytes_e_box” doesn’t work.
It works on Pytes V5. I only have 1 battery so I cannot test multiple battery. I checked: Battery current, SOC, Temperature, Voltage, Cell Voltage/Current/Base/temperature State, Events, Barcode, State, etc. It doesn’t show the cells voltages. It only show Normal State. Can you modify the code?
I managed to get this great piece of work deployed in my Home Assistant and Pytes Battery setup.
The board I used is a generic WROOM-32D ESP32 dev board from Aliexpress. It has 30 pins only, therefore I used GPIO5 and GPIO4, instead of GPIO6. I hope that makes sense.
I have two Pytes V5 batteries, installed in an external Nema 3 outdoor box
After some trial and error, below is the wiring diagram that I have put together.
The main issue I faced was the wifi signal range. The wifi signal is weak since my batteries are installed in an external area. The wifi strength of the ESP32 board which I have got is also very poor. I will order a new board with a design in which the wifi antenna is detached from the PCB. Let’s hope that can improve.
An update, my ESP32 board Wifi works okay if I use a 5V power supply via the Vin pin, rather than using the USB-C socket as power source.
I was told that is due to poor Chinese board design and manufacturing that, when the board is fed from a 5V USB-C power source, the same 5V power is used to feed the CH340C chip, and the chip output 5V signal to the ESP32. Since ESP32 is supposed to work with 3.3V signal only, this causes significant interference in the circuit and distorts the Wifi performance.
I got it running and displaying data in ha but I’m not sure if this is a bug or if I’m doing something wrong.
[15:00:06][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 3]
[15:00:06][I][pytes_e_box:079]: Retry command from queue: bat 3 from index: 6 (2)
[15:00:06][I][pytes_e_box:079]: Retry command from queue: bat 3 from index: 6 (3)
[15:00:06][I][pytes_e_box:079]: Retry command from queue: bat 3 from index: 6 (4)
[15:00:07][W][component:237]: Component pytes_e_box took a long time for an operation (102 ms).
[15:00:07][W][component:238]: Components should block for at most 30 ms.
[15:00:07][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 3]
[15:00:07][I][pytes_e_box:079]: Retry command from queue: bat 3 from index: 6 (5)
[15:00:07][W][component:237]: Component pytes_e_box took a long time for an operation (143 ms).
[15:00:07][D][pytes_e_box:258]: parsed command -> Battery Data Index [Battery: 3]
[15:00:07][I][pytes_e_box:145]: PytesEBox command queue done.
[15:00:27][D][pytes_e_box:101]: Sending command from queue: pwr from index: 0
[15:00:27][W][component:237]: Component pytes_e_box took a long time for an operation (206 ms).
[15:00:27][W][component:238]: Components should block for at most 30 ms.
[15:00:27][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 0]
[15:00:27][I][pytes_e_box:079]: Retry command from queue: pwr from index: 0 (0)
[15:00:28][W][component:237]: Component pytes_e_box took a long time for an operation (102 ms).
[15:00:28][W][component:238]: Components should block for at most 30 ms.
[15:00:28][W][component:237]: Component pytes_e_box took a long time for an operation (77 ms).
[15:00:28][D][pytes_e_box:258]: parsed command -> Power Data [Battery: 0]
[15:00:28][D][sensor:093]: 'Battery 1 Voltage': Sending state 53.70700 V with 3 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 1 Current': Sending state 714.00000 mA with 3 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 1 Temperature': Sending state 26.00000 °C with 1 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 1 State of Charge': Sending state 75.00000 % with 0 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 2 Voltage': Sending state 53.69500 V with 3 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 2 Current': Sending state -374.00000 mA with 3 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 2 Temperature': Sending state 27.00000 °C with 1 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 2 State of Charge': Sending state 75.00000 % with 0 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 3 Voltage': Sending state 53.69200 V with 3 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 3 Current': Sending state -2582.00000 mA with 3 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 3 Temperature': Sending state 26.00000 °C with 1 decimals of accuracy
[15:00:28][D][sensor:093]: 'Battery 3 State of Charge': Sending state 64.00000 % with 0 decimals of accuracy
[15:00:28][E][pytes_e_box:338]: invalid line: found only 1, should be 23 items. in line 8
: 8 - - - ?? - - - ?????? - ?j? - - - - - - -
[15:00:28][E][pytes_e_box:338]: invalid line: found only 1, should be 23 items. in line 10
: 10 - ?jjjjjj???? - - - - - - - ?j? ??j? ?
[15:00:28][D][pytes_e_box:101]: Sending command from queue: pwr 1 from index: 1
[15:00:28][W][component:237]: Component pytes_e_box took a long time for an operation (109 ms).
[15:00:28][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 1]
[15:00:28][I][pytes_e_box:079]: Retry command from queue: pwr 1 from index: 1 (0)
[15:00:28][W][component:237]: Component pytes_e_box took a long time for an operation (90 ms).
[15:00:29][W][component:238]: Components should block for at most 30 ms.
[15:00:29][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 1]
[15:00:29][I][pytes_e_box:079]: Retry command from queue: pwr 1 from index: 1 (1)
[15:00:29][I][pytes_e_box:079]: Retry command from queue: pwr 1 from index: 1 (2)
[15:00:29][W][component:237]: Component pytes_e_box took a long time for an operation (160 ms).
[15:00:29][I][pytes_e_box:079]: Retry command from queue: pwr 1 from index: 1 (3)
[15:00:32][E][pytes_e_box:129]: timeout command from queue: pwr 1 with 4 retries
[15:00:32][D][pytes_e_box:101]: Sending command from queue: bat 1 from index: 2
[15:00:32][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 1]
[15:00:32][I][pytes_e_box:079]: Retry command from queue: bat 1 from index: 2 (0)
[15:00:33][W][component:237]: Component pytes_e_box took a long time for an operation (108 ms).
[15:00:33][W][component:238]: Components should block for at most 30 ms.
[15:00:33][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 1]
[15:00:33][I][pytes_e_box:079]: Retry command from queue: bat 1 from index: 2 (1)
[15:00:33][W][component:237]: Component pytes_e_box took a long time for an operation (72 ms).
[15:00:33][D][pytes_e_box:258]: parsed command -> Battery Data Index [Battery: 1]
[15:00:33][E][pytes_e_box:308]: invalid line: found only 7, should be 9 items. in line 9
: 9 3352 25000 Dischg Normal Normal Norma???*?????j
[15:00:33][E][pytes_e_box:308]: invalid line: found only 1, should be 9 items. in line 10
: 10 ?&?????"????? Normal Normal Normal 76% 76077 m
[15:00:33][D][pytes_e_box:101]: Sending command from queue: pwr 2 from index: 3
[15:00:33][W][component:237]: Component pytes_e_box took a long time for an operation (94 ms).
[15:00:33][D][pytes_e_box:258]: parsed command -> Power Data Index [Battery: 2]
[15:00:34][D][pytes_e_box:101]: Sending command from queue: bat 2 from index: 4
[15:00:34][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 2]
[15:00:34][I][pytes_e_box:079]: Retry command from queue: bat 2 from index: 4 (0)
[15:00:34][W][component:237]: Component pytes_e_box took a long time for an operation (86 ms).
[15:00:34][W][component:238]: Components should block for at most 30 ms.
[15:00:34][I][pytes_e_box:079]: Retry command from queue: bat 2 from index: 4 (1)
[15:00:34][W][component:237]: Component pytes_e_box took a long time for an operation (138 ms).
[15:00:34][I][pytes_e_box:079]: Retry command from queue: bat 2 from index: 4 (2)
[15:00:35][W][component:237]: Component pytes_e_box took a long time for an operation (122 ms).
[15:00:35][W][component:238]: Components should block for at most 30 ms.
[15:00:35][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 2]
[15:00:35][I][pytes_e_box:079]: Retry command from queue: bat 2 from index: 4 (3)
[15:00:38][E][pytes_e_box:129]: timeout command from queue: bat 2 with 4 retries
[15:00:38][D][pytes_e_box:101]: Sending command from queue: pwr 3 from index: 5
[15:00:38][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 3]
[15:00:38][I][pytes_e_box:079]: Retry command from queue: pwr 3 from index: 5 (0)
[15:00:38][W][component:237]: Component pytes_e_box took a long time for an operation (92 ms).
[15:00:38][W][component:238]: Components should block for at most 30 ms.
[15:00:38][I][pytes_e_box:079]: Retry command from queue: pwr 3 from index: 5 (1)
[15:00:38][I][pytes_e_box:079]: Retry command from queue: pwr 3 from index: 5 (2)
[15:00:38][I][pytes_e_box:079]: Retry command from queue: pwr 3 from index: 5 (3)
[15:00:39][W][component:237]: Component pytes_e_box took a long time for an operation (178 ms).
[15:00:39][W][component:238]: Components should block for at most 30 ms.
[15:00:39][D][pytes_e_box:258]: parsed command -> Not in List [Battery: 3]
[15:00:39][I][pytes_e_box:079]: Retry command from queue: pwr 3 from index: 5 (4)
[15:00:39][W][component:237]: Component pytes_e_box took a long time for an operation (104 ms).
[15:00:39][D][pytes_e_box:258]: parsed command -> Power Data Index [Battery: 3]
[15:00:40][D][pytes_e_box:101]: Sending command from queue: bat 3 from index: 6
[15:00:40][W][component:237]: Component pytes_e_box took a long time for an operation (51 ms).
[15:00:40][W][component:238]: Components should block for at most 30 ms.
[15:00:40][D][pytes_e_box:258]: parsed command -> Battery Data Index [Battery: 3]
[15:00:40][E][pytes_e_box:308]: invalid line: found only 7, should be 9 items. in line 1
: 1 3358 26000 Dischg Normal Normal Normal ???*??¢?j
[15:00:40][E][pytes_e_box:308]: invalid line: found only 7, should be 9 items. in line 3
: 3 3355 26000?"????? Normal Normal Normal 66% 66847 m
[15:00:40][E][pytes_e_box:308]: invalid line: found only 2, should be 9 items. in line 4
: 4 3349 ????00?"????? Normal Normal Normal ???*?????j
[15:00:40][E][pytes_e_box:308]: invalid line: found only 7, should be 9 items. in line 6
: 6 3350 26000 Dischg Normal ?r????? Normal 65% 65990 m
[15:00:40][E][pytes_e_box:308]: invalid line: found only 1, should be 9 items. in line 8
: 8 ??????????"????? Normal Normal Normal 64% 64121 m
[15:00:40][E][pytes_e_box:308]: invalid line: found only 7, should be 9 items. in line 9
: 9 3357 26000 ?Z?,? Normal Normal ?9????? ???*?????j
[15:00:40][E][pytes_e_box:308]: invalid line: found only 7, should be 9 items. in line 11
: 11 3356 25000 Dischg Normal Normal No?[X??*?????j
[15:00:40][E][pytes_e_box:308]: invalid line: found only 7, should be 9 items. in line 14
: 14 3349 25000 Dischg ?r????? Normal Normal 65% 65321 m
[15:00:40][E][pytes_e_box:308]: invalid line: found only 2, should be 9 items. in line 15
: 15 33MM?????"????? Normal Normal Normal 66% ???Sj
[15:00:40][I][pytes_e_box:145]: PytesEBox command queue done.
[15:00:41][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
