Python 3.6.x upgrade
Is there a good guide about upgrading python to 3.6.x release on hassbian running HA 0.94.1 ?
Yes, it is mentioned in the release notes.
sudo hassbian-config upgrade python
Can you give me the link of the release notes… cannot find it… :laughing:
The current Release Notes are always on the homeassistant.io main page.
says this:
If you are using hassbian, you can upgrade Python by following these instructions.
which links to:
Thanks a lot…
Hi
I PuTTY’ed into my Pi and ran the command:
and it said:
This script will change a lot on your pi.
DO NOT run this if it’s not absolutely necessary
You can force run the upgrade script like this:
sudo hassbian-config upgrade python --force
So I tried
and it came back with:
It is NOT recomended to run this.
Are you absolutely sure you want to run this script? [N/y]:
I obviously said “No”.
