Python 3.7 errors with hassio, lost cloud connectivity and abode integration
Lost connectivity when I changed routers but might just be a coincidence, though I hadn’t upgraded. After it stopped working I updated to 0.92.2 but it’s still not connecting (but hassio can ping addresses so it had connectivity). This is in my logs:
Log Details (ERROR)
Wed May 15 2019 22:22:16 GMT-0400 (Eastern Daylight Time)
Error during setup of component abode
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File “/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py”, line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File “/usr/local/lib/python3.7/socket.py”, line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 600, in urlopen
chunked=chunked)
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 343, in _make_request
self._validate_conn(conn)
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 839, in _validate_conn
conn.connect()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 301, in connect
conn = self._new_conn()
File “/usr/local/lib/python3.7/site-packages/urllib3/connection.py”, line 168, in _new_conn
self, “Failed to establish a new connection: %s” % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x72a40590>: Failed to establish a new connection: [Errno -3] Try again
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 449, in send
timeout=timeout
File “/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py”, line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py”, line 399, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘my.goabode.com’, port=443): Max retries exceeded with url: /api/auth2/login (Caused by NewConnectionError(’<urllib3.connection.VerifiedHTTPSConnection object at 0x72a40590>: Failed to establish a new connection: [Errno -3] Try again’))
File “/usr/local/lib/python3.7/site-packages/homeassistant/setup.py”, line 156, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/abode/init.py”, line 129, in setup
username, password, cache, name, polling, exclude, lights)
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/abode/init.py”, line 90, in init
get_automations=True, cache_path=cache)
File “/usr/local/lib/python3.7/site-packages/abodepy/init.py”, line 99, in init
self.login()
File “/usr/local/lib/python3.7/site-packages/abodepy/init.py”, line 132, in login
response = self._session.post(CONST.LOGIN_URL, json=login_data)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 581, in post
return self.request(‘POST’, url, data=data, json=json, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 646, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘my.goabode.com’, port=443): Max retries exceeded with url: /api/auth2/login (Caused by NewConnectionError(’<urllib3.connection.VerifiedHTTPSConnection object at 0x72a40590>: Failed to establish a new connection: [Errno -3] Try again’))
Can someone point me in a direction?
Did you ever get this resolved? I’m having a similar/the same problem now.
Thanks,
-joni-
I ended up reinstalling Hassio. Has been working fine for about a year and now it started doing it again. No *&#$_%# clue what is causing this to randomly start happening. Really don’t want to go through the reinstall all over again… did you happen to figure out what the issue was?
Nope, I did the same thing you did. I’m running unsupported on Ubuntu currently and take full snaps in HA and snapshots of the Ubuntu VM every time update anything (HA, HACS, etc) that isn’t just config. Been solid for sometime and I don’t upgrade HA often and even then check the forum for reports of issues beforehand.
