Home Assistant release with the issue:
0.112.0
Operating environment (HassOS/Generic):
Ubuntu
Supervisor logs:
20-07-02 09:48:57 INFO (SyncWorker_11) [supervisor.docker.interface] Start homeassistant/intel-nuc-homeassistant
20-07-02 09:49:02 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-07-02 09:49:22 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-07-02 09:49:22 INFO (MainThread) [supervisor.addons] Phase ‘AddonStartup.APPLICATION’ start 1 add-ons
20-07-02 09:49:22 INFO (SyncWorker_5) [supervisor.docker.interface] Clean addon_cebe7a76_hassio_google_drive_backup application
20-07-02 09:49:23 INFO (SyncWorker_5) [supervisor.docker.addon] Start Docker add-on sabeechen/hassio-google-drive-backup-amd64 with version 0.100.0
20-07-02 09:49:23 INFO (MainThread) [supervisor.api.security] /homeassistant/info access from cebe7a76_hassio_google_drive_backup
20-07-02 09:49:23 INFO (MainThread) [supervisor.api.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
20-07-02 09:49:23 INFO (MainThread) [supervisor.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
20-07-02 09:49:23 INFO (MainThread) [supervisor.api.security] /snapshots/73acca6f/info access from cebe7a76_hassio_google_drive_backup
20-07-02 09:49:23 INFO (MainThread) [supervisor.api.security] /snapshots/a6261e32/info access from cebe7a76_hassio_google_drive_backup
20-07-02 09:49:23 INFO (MainThread) [supervisor.api.security] /snapshots/a885b964/info access from cebe7a76_hassio_google_drive_backup
20-07-02 09:49:23 INFO (MainThread) [supervisor.api.security] /snapshots/63506f9d/info access from cebe7a76_hassio_google_drive_backup
20-07-02 09:49:28 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-07-02 09:49:28 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-07-02 09:49:28 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-07-02 09:49:28 INFO (MainThread) [supervisor.host.info] Update local host information
20-07-02 09:49:28 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-07-02 09:49:28 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-02 09:49:28 INFO (MainThread) [supervisor.host.services] Update service information
20-07-02 09:49:28 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-02 09:49:28 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-02 09:49:28 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-02 09:49:28 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
Description of problem:
i`ve restarted my nuc today and notice a spike in internet trafic… went further and noticed this:
any idea what this might be?
also getting this at restart:
2020-07-02 13:10:20 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback EventBus.async_listen_once…onetime_listener(<Event homeassistant_stop[L]>) at /usr/src/homeassistant/homeassistant/core.py:680
TypeError: stop() takes 1 positional argument but 2 were given
2020-07-02 13:16:12 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback EventBus.async_listen_once…onetime_listener(<Event homeassistant_stop[L]>) at /usr/src/homeassistant/h>
File “/usr/local/lib/python3.7/asyncio/events.py”, line 88, in _run
self._context.run(self._callback, *self._args)
File “/usr/src/homeassistant/homeassistant/core.py”, line 692, in onetime_listener
self._hass.async_run_job(listener, event)
File “/usr/src/homeassistant/homeassistant/core.py”, line 401, in async_run_job
self.async_add_job(target, *args)
File “/usr/src/homeassistant/homeassistant/core.py”, line 331, in async_add_job
task = self.loop.create_task(target(*args))
later edit… found this as well:
[s6-finish] waiting for services.
2020-07-02 13:57:15 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback EventBus.async_listen_once..onetime_listener(<Event homeassistant_stop[L]>) at /usr/src/homeassistant/homeassistant/core.py:680
self.hass.async_run_job(listener, event)
Error doing job: Exception in callback async_track_state_change..state_change_listener(<Event state…879542+03:00>>) at /usr/src/homeassistant/homeassistant/helpers/event.py:81
self._context.run(self._callback, *self.args)
File “/usr/src/homeassistant/homeassistant/helpers/event.py”, line 103, in state_change_listener
event.data.get(“new_state”),
File “/usr/src/homeassistant/homeassistant/core.py”, line 336, in async_add_job
None, target, *args
File “/usr/local/lib/python3.7/asyncio/base_events.py”, line 755, in run_in_executor
executor.submit(func, *args), loop=self)
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 163, in submit
raise RuntimeError(‘cannot schedule new futures after shutdown’)
RuntimeError: cannot schedule new futures after shutdown
Error doing job: Exception in callback async_track_state_change..state_change_listener(<Event state…880216+03:00>>) at /usr/src/homeassistant/homeassistant/helpers/event.py:81
None, target, *args
Error doing job: Exception in callback async_track_state_change..state_change_listener(<Event state…880793+03:00>>) at /usr/src/homeassistant/homeassistant/helpers/event.py:81
None, target, *args
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] udev.sh: executing…
[13:57:23] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
