My Xiaomi MiBox 3 does not want to show up in Home assistant.
If I wipe both
androidtv_adbkey
androidtv_adbkey.pub
and reboot, the Mibox will ask me to accept the connection from HASS.
After accepting the connection, both files will be recreated.
However, no “adb” or “android” or “MIBOX3” shows up under entities.
The automatic lovelace dashboard also does not show up any new entries.
There are also no logs regarding this situation, only irrelevant lines about offline printers etc.
I’ve copied the example from the android TV docs, and only changed the IP. No change.
media_player:
** - platform: androidtv
** name: Android TV 1
** host: IP address
In the past I’ve had the old ADB method running, but that was on a different system, of which I only copied the config files and nothing more.
I have no clue on how to fix this, to get the Android TV entities to show up in Home assistant.
I’ve been searching on the internet for a few months now, but nothing similar to this showed up.
Does anyone have any tips or ideas?
System info:
System Health
version | core-2021.12.5 |
installation_type | Home Assistant OS |
dev | false |
hassio | true |
docker | true |
user | root |
virtualenv | false |
python_version | 3.9.7 |
os_name | Linux |
os_version | 5.10.83 |
arch | x86_64 |
timezone | Europe/Amsterdam |
Home Assistant Community Store
GitHub API | ok |
Github API Calls Remaining | 4891 |
Installed Version | 1.18.0 |
Stage | running |
Available Repositories | 931 |
Installed Repositories | 4 |
Home Assistant Cloud
logged_in | false |
can_reach_cert_server | ok |
can_reach_cloud_auth | ok |
can_reach_cloud | pending |
Home Assistant Supervisor
host_os | Home Assistant OS 7.0 |
update_channel | stable |
supervisor_version | supervisor-2021.12.2 |
docker_version | 20.10.9 |
disk_total | 7.2 GB |
disk_used | 3.9 GB |
healthy | true |
supported | true |
board | ova |
supervisor_api | ok |
version_api | ok |
installed_addons | Samba share (9.5.1), Terminal & SSH (9.2.2), Check Home Assistant configuration (3.9.0), Let’s Encrypt (4.12.0), File editor (5.3.3), Google Assistant SDK (2.5.0) |
Lovelace
dashboards | 2 |
resources | 0 |
views | 1 |
mode | storage |
Spotify
api_endpoint_reachable | ok |
