I have a similar issue since I upgraded my OS and core to the latest version.
I’m getting a notification of invalid config.
From what I found out, default config can’t load the stream integration.
The stream integration can’t load because of a missing python file…
(Haos running on Pi2)
Logger: homeassistant.setup
Source: setup.py:416
First occurred: 11:07:23 (1 occurrences)
Last logged: 11:07:23
Error during setup of component stream
File "/usr/src/homeassistant/homeassistant/setup.py", line 416, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 226, in async_setup
await hass.async_add_executor_job(set_pyav_logging, debug_enabled)
File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/stream/__init__.py", line 196, in set_pyav_logging
import av # pylint: disable=import-outside-toplevel
File "/usr/local/lib/python3.13/site-packages/av/__init__.py", line 3, in <module>
from av._core import time_base, library_versions, ffmpeg_version_info
ImportError: Error loading shared library : No such file or directory (needed by /usr/local/lib/python3.13/site-packages/av/../av.libs/libjxl-2cfeb5f2.so.0.10.2)
