Python pip venv installation - missing hassio tab
I am a bit confused about installing process
It seems clear home assistant and hassio are 2 different “entities” that are meant to work together but, unfortunately , the installation instructions are not clear about adding hassio environment when/after installing homeassistant using pip therefore I am missing the hassio tab
How do one add hassio environment to a pip installed homeassistant ?
Can anyone please clarify and/or provide links to documentation for doing the following
install HA +HASSIO on a Linux server using pip and virtual environment
install HA + HASSIO on a linux server using containers
Many thanks
Steven
If you installed via Venv, you will not have a HassIO tab.
HA can run in venv or it can run on top of HassIO (in docker).
You can’t.
If you want hassio, you need to install hassio. You can’t add hassio capabilities to a venv installed instance of home assistant.
https://www.home-assistant.io/hassio/installation/#alternative-install-on-a-generic-linux-host
Thank you for taking the trouble to respond
So, just to clarify further
  1. both hassio and HA allows to manage devices - they ARE different products working the same way
  2. hassio allows managing addons easier ( from UI) but manual config is a more complicated
  3. HA require adding addons manually
  4. HA can be installed using pip while hassio requires using docker but both have easy installs on RAsberry PI
Would anyone be willing to confirm the above ?
It seems the main differences are related to installation
From a functionality perspective is there anything I am missing / should know ?
Steven
Hassio is ONE installation method of Home Assistant. Home Assistant is Home Assistant. Add-ons from hassio are other applications that work with Home Assistant, or are other services. They are all able to be replicated with any other installation method with some work and effort on your part.
addons are a Hassio-ONLY thing. Home Assistant is still Home Assistant, and everything thing you see in “integrations/components” page on the website are available on every instance of Home Assistant no matter how you installed it.
applications
Correct.
Exactly.
Basically understand that Home Assistant is the application. Hassio is one way to install home assistant in your network. The others are home assistant docker, or python virtual environment. Functionality of Home Assistant itself is the same across the board. Add-ons are merely other applications that ADD functionality, but are not required for Home Assistant to work as Home Assistant.
