Hi there!
I want to update the state of a sensor via a python script on another machine.
So far, I have
import requests
def hassrequest(state):
hassurl = 'http://192.168.0.89:8123/api/states/sensor.xyz_status'
token = "Bearer [token]"
data = {"state": state,
"attributes": {"unit_of_measurement": "", "friendly_name": "XYZ Status"}}
headers = {"Authorization": token,
"Content-Type": "application/json"}
try:
hassstatus = requests.post(hassurl, data=data, headers=headers ,timeout=1)
print("RAN THE POST")
except requests.exceptions.RequestException:
print("EXCEPTION")
print(headers)
print(data)
hassrequest("TEST2")
but doesn’t seem to do anything. I can’t see any logged events in the GUI either.
The header is: {'Authorization': 'Bearer [token]', 'Content-Type': 'application/json'}
The data is {'state': 'TEST2', 'attributes': {'unit_of_measurement': '', 'friendly_name': 'XYZ Status'}}
If I run
curl -X POST
-H "Authorization: Bearer [token]"
-H "Content-Type: application/json"
-d '{"state": "TEST1", "attributes": {"unit_of_measurement": "", "friendly_name": "XYZ Status"}}'
http://192.168.0.89:8123/api/states/sensor.XYZ_status
then the status updates fine.
I can’t seem to find what the issue is.
Thanks!
