Hi
So I know this question has been arround before, but I can’t find an accurate answer.
Here is the issue I have been updating a thirdparty integration which uses a Python Libuary. I have installed the integration and it works as expected. It uses a libuary which is declaried in the manifest.
Now according to the doumentation, I have found, the requirements should be loaded into the ‘/config/homeassistant/deps directory’. But this is empty yet it works ! Which means it must be some where else. I have looked in all the usual places but no can’t find it.
Any clues greatly received, please be gently very new at this !!!
cheers Tim
hassos: “11.1”
homeassistant: 2023.11.2
hostname:
logging: info
machine: yellow
operating_system: Home Assistant OS 11.1
state: running
supervisor: 2023.11.3
supported: true
supported_arch:
- aarch64
- armv7
- armhf
