Python script datetime local time
Hi
After upgrading to 0.118 seems that the datetime in python script is returning UTC and not local time. Is this the case?
Any solution?
Thx
More information:
In previous HA versions, calling the following returns correct local time:
"{{ as_timestamp(states('input_datetime.reminder2_date')) | timestamp_local }}"
in 0.118 I need to change it to UTC to get correct local time.
"{{ as_timestamp(states('input_datetime.reminder2_date')) | timestamp_utc }}"
Any idea why?
The good news is that it’s a known problem, there’s an open Issue in the Core repository, balloob is taking care of it and has created a PR to correct it. You can follow the discussion here:
Ended up here trying to find a way to get the current time in seconds in the local timezone in order to update my lights correctly in a circadian rhythm script I’ve written. Previously I used datetime.datetime.now(), but that returned a datetime in UTC. Tried using the dt_util.as_local, but that seemed to return the same datetime. Tried to use the dt_util.get_time_zone in order to create a tzinfo object to pass to datetime.datetime.now(), but that also failed because access to dt_util.get_time_zone is restricted.
Finally realised that there is a dt_util.now() function and looking at the source code, it seemed to use the default timezone! This actually works and I now am able to get the correct amount of seconds using datetime.timedelta(hours=now.hour,minutes=now.minute,seconds=now.second).total_seconds()
Shame there seems to be no documentation for the dt_util library and the documentation for the Python scripts is also rather minimal. Hope that others struggling with this issue find this and are able to solve their issues.
I know this is a very
I know that this is a very old thread, but yes, your answer helped me. Unfortunately the Python scripts documentation is still almost non-existent. Which is a bummer for me, because before I write more than a single line of jinja in a YAML-file I’d rather create a Python script, even though there’s a lot more boiler plate code necessary. It’s just so much easier to read, write and debug.
Before I found your post my way to get a timezone value was to pick it off a date created with fromisoformat(), which returns a datetime with a tzinfo property, and then fed it to datetime.datetime.now() like
datetime.datetime.now(datetime.datetime.fromisoformat('2026-07-18 00:00:00.000+00:00').tzinfo)
I couldn’t believe that round-about way had to be the solution (and I don’t understand why the timezone class of the datetime module isn’t accessible) just to be able to subtract “now” from given date (which ran into a “can't subtract offset-naive and offset-aware datetimes” Python error). dt_util.now() is obviously much more readable. So thank you!
