I’m trying to write a python_script service which will allow a light time to have blackouts.
To set up the actual times for this I am using the automation:
- id: shower_timer_id
alias: Shower Timer
- entity_id: switch.master_shower_switch
for:
seconds: 60
platform: state
to: 'on'
for:
seconds: 5
platform: state
to: 'off'
- alias: tell me
message: shower message
service: notify.ios_devansiphone7
- data:
service: python_script.timed_off
The idea being, when we are off for less than 5 seconds, we will be in a “blackout” window the next time we turn on which will prevent the timer from turning off the light.
The actual script is as follows:
entity_id = data.get('entity_id')
states = hass.states.get(entity_id)
atts = states.attributes.copy()
if states.state == "off":
hass.services.call('notify', 'ios_devansiphone7', {'message': 'blackout disabled', 'title':'timed_off'})
logger.info('Cleared Blackout for ' + str(entity_id))
atts['blackout'] = False
hass.states.set(entity_id, states.state, atts)
else:
if states.attributes.get('blackout') == False:
hass.services.call('notify', 'ios_devansiphone7', {'message': 'Turning off shower', 'title':'timed_off'})
logger.info('Tuning off ' + str(entity_id))
atts['blackout'] = True
data = { "entity_id" : entity_id }
hass.services.call('light', 'turn_off', data)
else:
hass.services.call('notify', 'ios_devansiphone7', {'message': 'blackout observed', 'title':'timed_off'})
logger.info('Timer disabled on blackout')
Eventually I think this ends up sending me a notification that the light is on and allowing me to take action based on response but here was a the rough cut to test the idea. The problem that I’m seeing right now is that the “blackout” attribute never appears to be set on the switch. I’m not very confident that I can even create arbitrary attributes for an entity so I was hoping for that clarification first, can anyone confirm?
Thanks,
Devan
