I need some help with the logging of a python script. The script is already working the half way, but I need some logging from the script.
I already enabled the logging in Home assistant in the configuration.yaml
logger:
default: warning
logs:
homeassistant.components.python_scripts: debug
In the python script I also have some logging. For example:
logger.info (“Licht wird heller gestellt”)
After the configuration I restarted the home assistant, but I can’t find any logs, after I call the python script service, in the home-assistant.log
Thank you for your help.
