BigFan
1
Good day
This trigger fires okay, but input_boolean.ss_battery_charging is not set. Any help would be appreciated.
Thank you
- trigger:
platform: state
entity_id: sensor.ss_battery_power
- service: python_script.set_state
data_template:
state: >-
{% set charging = (states.sensor.ss_battery_power.state | int ) %}
{% if charging < 0 %}
on
{% else %}
off
{% endif %}
entity_id: input_boolean.ss_battery_charging
petro
(Petro)
2
Why are you using the python script? This is what template sensors are for, no automation needed.
template:
- binary_sensor:
- name: SS Battery Charging
unique_id: ss_battery_charging
state: "{{ states('sensor.ss_battery_power') | int < 0 }}"
availability: "{{ states('sensor.ss_battery_power') | is_number }}"
if you’re dead set on an automation, you still don’t need the python_Script.
platform: state
- service: homeassistant.turn_{{ iif(states('sensor.ss_battery_power') | int < 0, 'on', 'off') }}
IMO that python script is 100% unnecessary in almost every circumstance that it’s used.
BigFan
3
Thank you
I will try that
