I am trying to alter the modbus.yaml when the user changes an input on the UI (input_number.victron_IP)
It doesnt look like I can do this using an automation, however can I do this with a python script?
I have never used python scripts before so please be kind
you can indeed, but you still might need to reload for it to take effect. i recently did something similar for mqtt in appdaemon:
import socket
import yaml
import os
# Function to get the local IP address
def get_local_ip():
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
try:
s.connect(('10.255.255.255', 1))
IP = s.getsockname()[0]
except Exception:
IP = '127.0.0.1'
finally:
s.close()
return IP
# Get the current IP
current_ip = get_local_ip()
# Load the appdaemon configuration file
config_file = '/appdaemon/appdaemon.yaml'
with open(config_file, 'r') as file:
config = yaml.safe_load(file)
# Replace the with the current IP
config['appdaemon']['plugins']['MQTT']['client_host'] = current_ip
# Write the updated configuration back to the file
with open(config_file, 'w') as file:
yaml.safe_dump(config, file)
you can this to continuously loop or it up as a crontab job so it starts on boot/checks every x mins/hours
this is great news, many thanks. I have to admit I have never done a python script before so forgive me. I have tried to run this but it errors on line 22 (config_file = ‘/appdaemon/appdaemon.yaml’). When I look in the directory I can however see a file called this?
How would I go about opening a file and then replacing specific lines with something from an input_number filed on the UI?
If the Python script is in another area/folder, this one will come up. copy and replace it will the full path. i.e. /home/pi/HA/appdaemon/appdaemon.yaml Basically you need to make sure your python file knows where exactly it is on the pi.
“How would I go about opening a file and then replacing specific lines with something from an input_number filed on the UI?” there is a few different methods for this, but appdaemon has something called `listen_state’ that listens for a change on your entity before firing a script.
import appdaemon.plugins.hass.hassapi as hass
class updateSomeText(hass.Hass):
def initialize(self):
# Define the file path and the key to update
self.yaml_file_path = "/appdaemon/apps/configFile.yaml" #this one again if its in the app Damon file you can get away with the short file path, but outside the folder you will need to direct it
# Define the input_number entity to read from - this you can do or define it directly in the listen state.. i think its tidier this way
self.input_number_entity = "input_number.example_input"
# Listen for changes in the input_number entity
self.listen_state(self.updateSomeYAML, self.input_number_entity)
def updateSomeYAML(self, entity, attribute, old, new, kwargs):
# Read the current value from the input_number entity
value = self.get_state(self.input_number_entity)
# Load the YAML file
with open(self.yaml_file_path, "r") as file:
yaml_data = yaml.safe_load(file)
# Update the value in the YAML data
yaml_data['someVariable'] = value
# Write the updated YAML data back to the file
with open(self.yaml_file_path, "w") as file:
yaml.dump(yaml_data, file)
self.log(f"Updated YAML file: {self.yaml_file_path}")
I haven’t tested the above but the general work flow is there.
