Python script to change input_boolean value
I’m trying to make a python file that I can run from the command line to change the state of an input boolean
I currently have a script with this single line:
hass.states.set(motionstate, on)
which is probably completely wrong
This is my terminal when I try to run the script:
➜  ~ python3 /config/python_scripts/setstatemotion.py
  File "/config/python_scripts/setstatemotion.py", line 1, in <module>
    hass.states.set(motionstate, 'on')
NameError: name 'hass' is not defined
