Python_script to turn lights on and off on a precise schedule
I’m currently working on some automation to make my house spooky for Halloween.
One thing I’m trying to do is make my lights pulsate in time with a soundtrack I’m going to play as kids approach my front door. So I have an automation which starts the sound playing (by triggering a script running on a second Raspberry Pi), and I wanted to time the lights to match the sound. As a result, I wanted my light timings to be somewhat precise (accurate to within a half second or so).
I tried doing this by using a series of light.turn_on and delay commands – but that didn’t work. I found that the delay commands were basically “delay for at least this many seconds” and not precise or repeatable enough.
So I tried writing my first python_script. And quickly found the many limitations of the sandbox. (Are the limitations documented somewhere? I couldn’t find this, and had to resort to trial and error.)
I figured I’d share the trick I eventually came up with, which seems to work:
def sleep_until(seconds, logger):
  global start_time
  while (time.time() - start_time) < seconds:
      time.sleep(0.2)
  logger.info("Slept until {}: {}".format(seconds, time.time()-start_time))
start_time = time.time()
# Now interleave waiting until the right time and turning lights on/off:
sleep_until(2, logger)
hass.services.call(...)
sleep_until(4, logger)
sleep_until(5, logger)
FWIW, is there a way of accessing the logger in a function without passing it in as a parameter? Seems like a quirk of the sandbox.
