I’m running the docker home-assistant image on my arm odroid xu4 - besides that repo not having a ‘latest’ tag when I looked into it deployment and configuration was pretty straight forward and its working well.
Now - i also tried to deploy an offical docker image on x86 - that one runs into problems that I cannot explain to myself. I read that the error indicated a python 2.7 issue (I shall run python 3.5+) - however as I’m not touching the image I’m not sure how come?
I tried with latest as well as an elder 0.68.0 - same result.
As both servers also run for different purposes I didn’t look inside hass.io deployment, I believe a proper docker image should run with Dockerfile + docker-compose.yml w/o further host machine setup. That is workign on armhf - so I’m assuming I’m overseeing something here.
docker logs iot-home-assistant
File "/usr/lib/python2.7/runpy.py", line 151, in _run_module_as_main
mod_name, loader, code, fname = _get_module_details(mod_name)
File "/usr/lib/python2.7/runpy.py", line 109, in _get_module_details
return _get_module_details(pkg_main_name)
File "/usr/lib/python2.7/runpy.py", line 113, in _get_module_details
code = loader.get_code(mod_name)
File "/usr/lib/python2.7/pkgutil.py", line 283, in get_code
self.code = compile(source, self.filename, 'exec')
File "/usr/src/app/homeassistant/__main__.py", line 33
def validate_python() -> None:
SyntaxError: invalid syntax
cat docker-compose.yml
version: '3'
services:
homeassistant:
container_name: iot-home-assistant
image: homeassistant/home-assistant
volumes:
- ./config/config:/config
- ./config/usr/local/bin:/usr/local/bin
- /etc/localtime:/etc/localtime:ro
network_mode: host
