Hey all I get the following when trying to obtain my ssl cert. I have 80 and 443 forwarded to 80/443 on my raspberry pi. I am running the latest hassbian. any hellp would be apprecitated. Google and this forum has not turned up much. It looks like there is a 404 at the end when python is setting up.
pi@hassbian:~/certbot $ sudo ./certbot-auto certonly --standalone --standalone-supported-challenges http-01 --email [redacted] -d [redacted]
Bootstrapping dependencies for Debian-based OSes... (you can skip this with --no-bootstrap)
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Reading package lists... Done
Building dependency tree
Reading state information... Done
augeas-lenses is already the newest version (1.8.0-1+deb9u1).
ca-certificates is already the newest version (20161130+nmu1).
gcc is already the newest version (4:6.3.0-4).
libaugeas0 is already the newest version (1.8.0-1+deb9u1).
libffi-dev is already the newest version (3.2.1-6).
libssl-dev is already the newest version (1.1.0f-3).
openssl is already the newest version (1.1.0f-3).
python is already the newest version (2.7.13-2).
python-dev is already the newest version (2.7.13-2).
python-virtualenv is already the newest version (15.1.0+ds-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Creating virtual environment...
Installing Python packages...
Had a problem while installing Python packages.
pip prints the following errors:
Collecting argparse==1.4.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 11))
Downloading argparse-1.4.0-py2.py3-none-any.whl
Collecting pycparser==2.14 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 17))
Downloading pycparser-2.14.tar.gz (223kB)
Collecting asn1crypto==0.22.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 21))
Downloading asn1crypto-0.22.0-py2.py3-none-any.whl (97kB)
Collecting cffi==1.10.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 24))
Downloading cffi-1.10.0.tar.gz (418kB)
Collecting ConfigArgParse==0.12.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 61))
Downloading ConfigArgParse-0.12.0.tar.gz (41kB)
Collecting configobj==5.0.6 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 63))
Downloading configobj-5.0.6.tar.gz
Collecting cryptography==2.0.2 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 65))
Downloading cryptography-2.0.2.tar.gz (427kB)
Collecting enum34==1.1.2 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 96))
Downloading enum34-1.1.2.tar.gz (46kB)
Collecting funcsigs==1.0.2 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 99))
Downloading funcsigs-1.0.2-py2.py3-none-any.whl
Collecting idna==2.5 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 102))
Downloading idna-2.5-py2.py3-none-any.whl (55kB)
Collecting ipaddress==1.0.16 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 105))
Downloading ipaddress-1.0.16-py27-none-any.whl
Collecting linecache2==1.0.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 108))
Downloading linecache2-1.0.0-py2.py3-none-any.whl
Collecting ordereddict==1.1 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 111))
Downloading ordereddict-1.1.tar.gz
Collecting packaging==16.8 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 113))
Downloading packaging-16.8-py2.py3-none-any.whl
Collecting parsedatetime==2.1 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 116))
Downloading parsedatetime-2.1-py2-none-any.whl
Collecting pbr==1.8.1 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 119))
Downloading pbr-1.8.1-py2.py3-none-any.whl (89kB)
Collecting pyOpenSSL==16.2.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 122))
Downloading pyOpenSSL-16.2.0-py2.py3-none-any.whl (43kB)
Collecting pyparsing==2.1.8 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 125))
Downloading pyparsing-2.1.8-py2.py3-none-any.whl (54kB)
Collecting pyRFC3339==1.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 134))
Downloading pyRFC3339-1.0-py2.py3-none-any.whl
Collecting python-augeas==0.5.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 137))
Downloading python-augeas-0.5.0.tar.gz (90kB)
Collecting pytz==2015.7 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 139))
Downloading pytz-2015.7-py2.py3-none-any.whl (476kB)
Collecting requests==2.12.1 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 153))
Downloading requests-2.12.1-py2.py3-none-any.whl (574kB)
Collecting six==1.10.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 156))
Downloading six-1.10.0-py2.py3-none-any.whl
Collecting traceback2==1.4.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 159))
Downloading traceback2-1.4.0-py2.py3-none-any.whl
Collecting unittest2==1.1.0 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 162))
Downloading unittest2-1.1.0-py2.py3-none-any.whl (96kB)
Collecting zope.component==4.2.2 (from -r /tmp/tmp.96MNCtazz8/letsencrypt-auto-requirements.txt (line 165))
Exception:
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/commands/install.py", line 342, in run
requirement_set.prepare_files(finder)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/req/req_set.py", line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/req/req_set.py", line 554, in _prepare_file
require_hashes
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/req/req_install.py", line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/index.py", line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/index.py", line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/index.py", line 568, in _get_pages
page = self._get_page(location)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/index.py", line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/index.py", line 795, in get_page
resp.raise_for_status()
File "/opt/eff.org/certbot/venv/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/models.py", line 893, in raise_for_status
raise HTTPError(http_error_msg, response=self)
HTTPError: 404 Client Error: Not Found for url: https://www.piwheels.hostedpi.com/simple/zope-component/
Certbot has problem setting up the virtual environment.
We were not be able to guess the right solution from your pip
output.
Consult https://certbot.eff.org/docs/install.html#problems-with-python-virtual-environment
for possible solutions.
You may also find some support resources at https://certbot.eff.org/support/ .
