Only use the HassOS based Hass.io instructions with the usb and shutdown openssh if you have it runing, otherwise you wont be able to connect to the pi on port 22222
Once you are in try to run these commands
command: login
command: docker ps
find the “CONTAINER ID” for “homeassistant” (could be raspberrypi3-homeassistant)
command: docker exec -it (id for homeassistant container) /bin/bash
now run the commands found here to get the auth code. only using the “Pairing” instructions.
Once you get the auth code copy it and close the ssh window because you do not need it anymore.
Add the ip of your tv, and the auth code to the code you added in your configuration.yaml I mentioned at the beginning.
Now if someone could tell me how to get google home to change the input on the tv through pyvizio that would be awesome.
google home through the new cloud hass.io integration will allow me to turn the tv on and off quicker than smart cast and change the volume although the command is called brightness. I would like to change the volume command and add the command to change input.
Incredibly helpful! … Question about once you’re logged into the 22222 port of the hassos hassio root — do you actually need to download pyvizio? You mention to skip straight to the “pairing” steps, but those have a function that reference pyvizio.
