HI,
One of the two current clamps has been giving me some problems for a few days now.
I have already replaced the hardware but the problem remains the same:
[W]|[component:214]|Component modbus took a long time for an operation (0.08 s).|
[W]|[component:215]|Components should block for at most 20-30ms|
I’ll start by saying that this setup has always worked for me.
Below is the esphome code:
> substitutions:
> packages:
> esphome.esp_web_tools_example: github://esphome/example-configs/esp-web-tools/esp32.yaml@v1
> esphome:
> name_add_mac_suffix: false
> wifi:
> ssid: !secret wifi_ssid
> password: !secret wifi_password
> use_address: ${name}.local
> manual_ip:
> static_ip: 192.168.1.26
> gateway: 192.168.1.1
> subnet: 255.255.255.0
> api:
> uart:
> - id: uart_1
> tx_pin: GPIO17
> rx_pin: GPIO16
> baud_rate: 9600
> data_bits: 8
> stop_bits: 1
> parity: NONE
> modbus:
> - id: mod_bus_pzem1
> send_wait_time: 250ms
> uart_id: uart_1
> sensor:
> - platform: pzemac
> current:
> name: "Consumo da Enel A"
> voltage:
> name: "Consumo da Enel V"
> energy:
> name: "Consumo da Enel Wh"
> power:
> name: "Consumo da Enel W"
> frequency:
> name: "Consumo da Enel Hz"
> power_factor:
> name: "Consumo da Enel c"
> update_interval: 5s
> address: 0x03
> modbus_id: mod_bus_pzem1
> - platform: pzemac
> current:
> name: "Consumo Totale A"
> voltage:
> name: "Consumo Totale V"
> energy:
> name: "Consumo Totale Wh"
> power:
> name: "Consumo Totale W"
> frequency:
> name: "Consumo Totale Hz"
> power_factor:
> name: "Consumo Totale c"
> update_interval: 5s
> address: 0x02
> - platform: dht
> pin: GPIO2
> temperature:
> name: "Fotovoltaico Temperatura "
> humidity:
> name: "Fotovoltaico Umidità "
> update_interval: 60s
> button:
> - platform: template
> name: Reset counter Enel
> icon: "mdi:emoticon-outline"
> on_press:
> - pzemac.reset_energy: pzemac_3
> - delay: 500ms
> name: Reset Counter Totale
> on_press:
> - pzemac.reset_energy: pzemac_2
> - delay: 500ms
