Hi, I yet configure and used a pzem-004t with Tasmota for monitoring my home energy consumption.
Do you think it is possibile to use pzem-004t for solar system production monitoring?
If yes how I must connect the modult to the inverter?
Yes it is. Connect the coil around the L1
Thank you for answer.
What do you mean with L1?
I need to power on the pzem with the inverter output voltage and then put the coil around the L line of the inverter output?
Yes indeed
Ok thanks I will try
Yes! Exactly
