Pzem 004T v3 Energy reset
Hi, I’m trying to reset the energy of my three pzem but it doesn’t work. The log indicates the button is pressed but the energy does not reset.
esphome:
  friendly_name: Energy Monitor
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  level: debug
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "xxxx"
ota:
  password: "xxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Energy-Monitor Fallback Hotspot"
    password: "D3TIYYhX2HNE"
captive_portal:
uart:
  - id: ubus
    rx_pin: GPIO1
    tx_pin: GPIO3
    baud_rate: 9600
    stop_bits: 1
modbus:
  uart_id: ubus
  - platform: pzemac
    modbus_id: mbus
    address: 1
    current:
    voltage:
    energy:
    power:
    frequency:
      name: "ID1 Frequency"
    power_factor:
      name: "ID1 Power Factor"
    update_interval: 10s
  - platform: pzemac
    modbus_id: mbus
    address: 2
    current:
    voltage:
    energy:
    power:
    frequency:
      name: "ID2 Frequency"
    power_factor:
      name: "ID2 Power Factor"
  - platform: pzemac
    modbus_id: mbus
    address: 3
    current:
    voltage:
    energy:
    power:
    frequency:
      name: "ID3 Frequency"
    power_factor:
      name: "ID3 Power Factor"
button:
    on_press:
      - pzemac.reset_energy: pzemac_1
      - pzemac.reset_energy: pzemac_2
      - pzemac.reset_energy: pzemac_3
Any (verbose) logs?
do you mean I have to set the logger to verbose?
More in terms like
switch:
  - platform: uart
    name: "Reset KW Totali"
    data: [0x01, 0x42, 0x80, 0x11]
This is solution, thank’s
Perfect !
My pzem-004t code use double sensor ;
1: 2 second sample no register database
2 : 60 second register database
Pzem RX > Wemos D6
Pzem TX > Wemos D5
Codice ESPHOME
esphome:
  platform: ESP8266
  board: d1_mini
substitutions:
# Enable logging
logger:
api:
  password: "xxxxxx"
ota:
  password: "xxxxx"
wifi:
  ssid: "xxxxxx"
  password: "xxxxxxx"
  ap:
    ssid: "Contatore Fallback Hotspot"
    password: "xxxxxx"
captive_portal:
web_server:
  port: 80
# Example configuration entry
uart:
  rx_pin: D6
  tx_pin: D5
  baud_rate: 9600
time:
  - platform: sntp
modbus:
#                         Slow sensors for Home assistant                      #
  - platform: pzemac
    current:
      internal: true
      icon: "mdi:alpha-a-circle"
    voltage:
      internal: true
      icon: "mdi:alpha-v-circle"
    power:
      internal: true
      icon: "mdi:alpha-w-circle"
    power_factor:
      internal: true
    update_interval: 2s
  - platform: total_daily_energy
    name: "PZEM Consumption"
    power_id: w
    filters:
      - multiply: 0.001
    unit_of_measurement: kWh
    icon: mdi:counter
    accuracy_decimals: 1
    name: "PZEM Ampere_HI"
    lambda: |-
      if (id(aac).state) {
        return (id(aac).state);
      } else {
        return 0;
    unit_of_measurement: A
    update_interval: 2s
    name: "PZEM Ampere_SL"
    lambda: |-
      } else {
        return 0;
    update_interval: 200s
    lambda: |-
      if (id(vac).state) {
        return (id(vac).state);
      } else {
        return 0;
    unit_of_measurement: V
    update_interval: 2s
    lambda: |-
      } else {
        return 0;
    lambda: |-
      if (id(w).state) {
        return (id(w).state);
      } else {
        return 0;
    unit_of_measurement: W
    update_interval: 2s
    lambda: |-
      if (id(w).state) {
      } else {
        return 0;
    lambda: |-
      if (id(pf).state) {
        return (id(pf).state);
      } else {
        return 0;
    unit_of_measurement: φ
    icon: "mdi:angle-acute"
    update_interval: 2s
    lambda: |-
      if (id(pf).state) {
      } else {
        return 0;
switch:
  - platform: uart
Configuration.yaml :
utility_meter:
  daily_energy:
    source: sensor.pzem_consumption
    cycle: daily
  monthly_energy:
    cycle: monthly
Per registrare solo gli eventi dei sensori SL esposti e escluderi i dati ogni 2sec:
inserire nel configuration.yaml:
#https://home-assistant.io/components/recorder/
recorder:
  commit_interval: 30
  exclude:
    entities:
    - sensor.pzem_volt_hi
    - sensor.pzem_watt_hi
    - sensor.pzem_pf_hi
    - sensor.pzem_ampere_hi
What are the advantages of using slow sensors?
The sensor that updates quickly is only used to display the data, some appliances in the house have strange behavior, and you see every behavior. The slowly updating sensor is used to record data in the database and not fill it with data.
