PZEM-004t v3 Using ESPHome & HA: MODBUS CRC Check Failed
Hello! looking to get some help with my first Power Minitoring device.
Got myself a PZEM-004t v3, but struck a solid wall right off the bat.
ESPHome logs gives me the following error:
[00:08:13][W][modbus:105]: Modbus CRC Check failed! C022!=00
I’d love some help getting this going.
Here’s the code I used:
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
  # level: VERY_VERBOSE
api:
  encryption:
    key: "redacted"
ota:
  password: "redacted"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: redacted
    gateway: redacted
    subnet: redacted
  ap:
    ssid: "Pzemac Fallback Hotspot"
captive_portal:
uart:
  rx_pin: GPIO23
  tx_pin: GPIO22
  baud_rate: 9600
modbus:
  - platform: pzemac
    current:
      name: "PZEM-004T V3 Current"
    voltage:
      name: "PZEM-004T V3 Voltage"
    energy:
      name: "PZEM-004T V3 Energy"
    power:
      name: "PZEM-004T V3 Power"
    frequency:
      name: "PZEM-004T V3 Frequency"
    power_factor:
      name: "PZEM-004T V3 Power Factor"
    update_interval: 2s
Obvious things that I have checked for:
Have I checked if I’m not messing up Tx an Rx?:
Yes I have swapped and checked. I have the correct Tx/Rx Combo
Have I checked if I’m using code for the correct device version?
Yes The device is PZEM-004t v3. It uses MODBUS and the platform on ESPHome is: pzemac
I’m happy to provide any further information that might help figure things out
Do you have Tx esp32 connected to Rx PZEM and Rx esp32 to Tx PZEM?
Yes I do. I have checked for that. Both Tx an Rx LEDs light up on the pzem board when connected correctly
Have you tried other esp32 pins?
For example esp32: TX pin - GPIO1 and RX pin - GPIO3
Do you have PZEM powered by 5V?
I have several PZEMs running, but on esp8266 and they all work fine.
How I’m having the same problem… did u find the solution
