Hello together,
I’m wondering if its possible to set a dynamic below: value at sensor.in_range?
working code snipped:
interval:
- interval: 2s
then:
if:
condition:
sensor.in_range:
below: 23
then:
fan.turn_off: fan_1
I would like to have the below limit dynamical. It should be the value of a 2nd sensor plus an offset.
Here is my try:
interval:
- interval: 2s
then:
if:
condition:
sensor.in_range:
below: !lambda "return id(ntc_2).state + 1.0;"
then:
fan.turn_off: fan_1
But during compilation, i get the error: “expected float.”
Failed config
interval: [source ESP32_3_NTC.yaml:238]
- [source ESP32_3_NTC.yaml:238]
interval: 2s
then: [source ESP32_3_NTC.yaml:240]
if: [source ESP32_3_NTC.yaml:241]
condition: [source ESP32_3_NTC.yaml:242]
sensor.in_range: [source ESP32_3_NTC.yaml:243]
expected float.
below: !lambda |-
return id(ntc_2).state + 1.0; [source ESP32_3_NTC.yaml:245]
Any hint would be helpful, thank you in advance.
best regards, thomas
