Q: which repository to use?
as this is my first post, a short introduction to myself: my name is Ralf and i‘m quite new to Hass.io here.
I would give it a try coming from Domoticz, which is quite cool but does not offer that much and deep integration to products is use.
And here comes up my question: forgive me if this is stupid but i did not find any information so far.
Setting up hass.io with the prepared image was no problem at all, now i would like to start with some integrations like Tado and netatmo.
But i do not know which repository to use to install these extensions? Sure its quite simple…
Thanks for your help in advance!
Ralf
none!
home assistant fundamentally isn’t modular, so the vast majority of components you read about in the docs are built-in and don’t require installing anything. there are add-ons (see here https://home-assistant.io/addons/ and see the link at the bottom of that page) that are needed for specific functionality, but they’re not necessary for most stuff.
so just follow the instructions in the docs, add relevant lines to your configuration.yaml, and your components should be added to your home assistant instance.
hope that helps get you started.
Thanks very much for the fast help! Definitely helps me. Did not think it is that easy…
/Ralf
