Q: Why Nodon STPH-2-1-05 Shows Incorrect Temperature?
I have latest Home Assistant OS on RPi3, and encountered a problem with Nodon STPH-2-1-05 temperature/humidity sensor (Enocean profile A5-04-01). While humidity seems to be correct, temperature displayed is 15C instead of 23C. For reference I connected 2nd temperature sensor from Thermokon, it works correctly.
I have tried other options below, all same, doesn’t work.
min_temp: 0
max_temp: 40
or
range_from: 0
range_to: 250
Anyone can help?
Thanks in advance.
Current configuration YAML below.
enocean:
  device: /dev/ttyUSB0
  - name: Thermokon LC-SR04 Temp Sensor
    platform: enocean
    device_class: temperature
    min_temp: 0
    max_temp: 40
  - name: Nodon STPH-2-1-05 Temp Sensor
    platform: enocean
    min_temp: 0
    max_temp: 40
  - name: Nodon STPH-2-1-05 Humidity Sensor
    platform: enocean
    device_class: humidity
I’ve got the same problem :frowning: Anyone has a solution to this? Thanks a lot
