Hi. I have been looking at various guides but i cannot seem to get bridge configuration working. I have a static ip on the host side of bridge but it is ignored and for some reason DHCP on my router is still giving OS an IP address so I think QEMU/KVM is using default network xml for NAT. I know WIFI does not work as bridge - I am using a USB LAN adapter on the host as enx00e04c6806d9. My host is Ubuntu 22.04 desktop.
On host
$ip addr show
3: enx00e04c6806d9: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:e0:4c:68:06:d9 brd ff:ff:ff:ff:ff:ff
inet 10.33.66.202/24 brd 10.33.66.255 scope global noprefixroute enx00e04c6806d9
valid_lft forever preferred_lft forever
inet6 fe80::f140:19af:b295:f05a/64 scope link noprefixroute
5: bri0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether be:bf:37:80:a2:9e brd ff:ff:ff:ff:ff:ff
inet 10.33.66.201/24 brd 10.33.66.255 scope global noprefixroute bri0
inet6 fe80::bcbf:37ff:fe80:a29e/64 scope link
$ brctl show
bridge name bridge id STP enabled interfaces
br-b243d562082c 8000.02422484bcf5 no vethbd77fc2
bri0 8000.bebf3780a29e yes
docker0 8000.0242418b17a8 no vethc8401e9
This is my netplan bridge:
$sudo cat /etc/netplan/02-qemu-bridge.yaml
version: 2
renderer: NetworkManager
ethernets:
enp0s31f6:
dhcp4: false
dhcp6: false
bridges:
bri0:
interfaces: [enp0s31f6]
addresses: [10.33.66.201/24]
routes:
- to: default
via: 10.33.66.1
metric: 100
on-link: true
nameservers:
addresses: [194.168.4.100, 194.168.8.100]
parameters:
stp: true
forward-delay: 4
dhcp4: no
dhcp6: no
$ip route
default via 10.33.66.1 dev enx00e04c6806d9 proto static metric 100
default via 10.33.66.1 dev bri0 proto static metric 20100 onlink linkdown
10.33.66.0/24 dev enx00e04c6806d9 proto kernel scope link src 10.33.66.202 metric 100
10.33.66.0/24 dev bri0 proto kernel scope link src 10.33.66.201 metric 425 linkdown
169.254.0.0/16 dev enx00e04c6806d9 scope link metric 1000
172.17.0.0/16 dev docker0 proto kernel scope link src 172.17.0.1
172.19.0.0/16 dev br-b243d562082c proto kernel scope link src 172.19.0.1
For QEMU/KVM:
$ sudo virsh
Welcome to virsh, the virtualization interactive terminal.
Type: 'help' for help with commands
'quit' to quit
virsh # net-list
Name State Autostart Persistent
bridged-network active yes yes
virsh # net-dumpxml bridged-network
<network>
<name>bridged-network</name>
<uuid>84c2b57c-beda-434c-abcc-b8e271ebdc7d</uuid>
<forward mode='bridge'/>
<bridge name='bri0'/>
</network>
My hassio VM:
<domain type='kvm'>
<name>hass</name>
<uuid>7fe4c758-3a6b-4e74-9c42-9bbdd466ae7f</uuid>
<memory unit='KiB'>2146304</memory>
<currentMemory unit='KiB'>2146304</currentMemory>
<vcpu placement='static'>2</vcpu>
<os firmware='efi'>
<type arch='x86_64' machine='pc-i440fx-jammy'>hvm</type>
<boot dev='hd'/>
</os>
<features>
<acpi/>
<apic/>
</features>
<cpu mode='host-model' check='partial'/>
<clock offset='utc'>
<timer name='rtc' tickpolicy='catchup'/>
<timer name='pit' tickpolicy='delay'/>
<timer name='hpet' present='no'/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled='no'/>
<suspend-to-disk enabled='no'/>
</pm>
<devices>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type='file' device='disk'>
<driver name='qemu' type='qcow2'/>
<source file='/var/lib/libvirt/images/hassos-vm/haos_ova-14.1.qcow2'/>
<target dev='vda' bus='virtio'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/>
</disk>
<controller type='usb' index='0' model='ich9-ehci1'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x7'/>
</controller>
<controller type='usb' index='0' model='ich9-uhci1'>
<master startport='0'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0' multifunction='on'/>
</controller>
<controller type='usb' index='0' model='ich9-uhci2'>
<master startport='2'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x1'/>
</controller>
<controller type='usb' index='0' model='ich9-uhci3'>
<master startport='4'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x2'/>
</controller>
<controller type='pci' index='0' model='pci-root'/>
<interface type='network'>
<mac address='52:54:00:6e:33:d3'/>
<source network='bridged-network'/>
<model type='virtio'/>
<link state='up'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/>
</interface>
<serial type='pty'>
<target type='isa-serial' port='0'>
<model name='isa-serial'/>
</target>
</serial>
<console type='pty'>
<target type='serial' port='0'/>
</console>
<input type='mouse' bus='ps2'/>
<input type='keyboard' bus='ps2'/>
<tpm model='tpm-crb'>
<backend type='emulator' version='2.0'/>
</tpm>
<audio id='1' type='none'/>
<memballoon model='virtio'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/>
</memballoon>
</devices>
</domain>
virsh # start hass
Domain ‘hass’ started
virsh # console hass
Connected to domain ‘hass’
Escape character is ^] (Ctrl + ])
Welcome to Home Assistant
homeassistant login:
# ip addr show
2: enp0s2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 52:54:00:6e:33:d3 brd ff:ff:ff:ff:ff:ff
inet6 fe80::b04c:fc73:41d4:18f5/64 scope link noprefixroute
I have emptied iptables and will repopulate when I get this working. ufw is enabled still.
sudo iptables --list
Chain INPUT (policy DROP)
target prot opt source destination
ufw-before-logging-input all -- anywhere anywhere
ufw-before-input all -- anywhere anywhere
ufw-after-input all -- anywhere anywhere
ufw-after-logging-input all -- anywhere anywhere
ufw-reject-input all -- anywhere anywhere
ufw-track-input all -- anywhere anywhere
Chain FORWARD (policy DROP)
DOCKER-USER all -- anywhere anywhere
DOCKER-ISOLATION-STAGE-1 all -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
DOCKER all -- anywhere anywhere
ufw-before-logging-forward all -- anywhere anywhere
ufw-before-forward all -- anywhere anywhere
ufw-after-forward all -- anywhere anywhere
ufw-after-logging-forward all -- anywhere anywhere
ufw-reject-forward all -- anywhere anywhere
ufw-track-forward all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output all -- anywhere anywhere
ufw-before-output all -- anywhere anywhere
ufw-after-output all -- anywhere anywhere
ufw-after-logging-output all -- anywhere anywhere
ufw-reject-output all -- anywhere anywhere
ufw-track-output all -- anywhere anywhere
Chain DOCKER (2 references)
ACCEPT tcp -- anywhere 172.17.0.2 tcp dpt:5000
ACCEPT tcp -- anywhere 172.19.0.2 tcp dpt:51821
ACCEPT udp -- anywhere 172.19.0.2 udp dpt:51820
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2 all -- anywhere anywhere
RETURN all -- anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-2 (2 references)
DROP all -- anywhere anywhere
Chain DOCKER-USER (1 references)
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:netbios-ns
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:netbios-dgm
ufw-skip-to-policy-input tcp -- anywhere anywhere tcp dpt:netbios-ssn
ufw-skip-to-policy-input tcp -- anywhere anywhere tcp dpt:microsoft-ds
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:bootps
ufw-skip-to-policy-input udp -- anywhere anywhere udp dpt:bootpc
ufw-skip-to-policy-input all -- anywhere anywhere ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
ACCEPT icmp -- anywhere anywhere icmp destination-unreachable
ACCEPT icmp -- anywhere anywhere icmp time-exceeded
ACCEPT icmp -- anywhere anywhere icmp parameter-problem
ACCEPT icmp -- anywhere anywhere icmp echo-request
ufw-user-forward all -- anywhere anywhere
Chain ufw-before-input (1 references)
ufw-logging-deny all -- anywhere anywhere ctstate INVALID
DROP all -- anywhere anywhere ctstate INVALID
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
ufw-not-local all -- anywhere anywhere
ACCEPT udp -- anywhere mdns.mcast.net udp dpt:mdns
ACCEPT udp -- anywhere 239.255.255.250 udp dpt:1900
ufw-user-input all -- anywhere anywhere
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
ufw-user-output all -- anywhere anywhere
Chain ufw-logging-allow (0 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 10 LOG level warning prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
RETURN all -- anywhere anywhere ctstate INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
RETURN all -- anywhere anywhere ADDRTYPE match dst-type LOCAL
RETURN all -- anywhere anywhere ADDRTYPE match dst-type MULTICAST
RETURN all -- anywhere anywhere ADDRTYPE match dst-type BROADCAST
ufw-logging-deny all -- anywhere anywhere limit: avg 3/min burst 10
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT tcp -- anywhere anywhere ctstate NEW
ACCEPT udp -- anywhere anywhere ctstate NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
ACCEPT tcp -- anywhere anywhere tcp dpt:ssh
Chain ufw-user-limit (0 references)
LOG all -- anywhere anywhere limit: avg 3/min burst 5 LOG level warning prefix "[UFW LIMIT BLOCK] "
REJECT all -- anywhere anywhere reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
