kouny
February 27, 2024, 10:41am
1
Hi, I have a board with a QMC5883L connected to an ESP-12e and I set it to
oversampling: 512x
update_interval: 1s
No processing or publishing of any kind is done, only (automatic) logging to the console, when I connect to the device to see the logs.
Well it doesn’t comply with my request, I get a values surely less than once per second.
If I reduce to oversampling 128x, the values appear as expected once per second.
In principle, oversampling rate is tied to refresh, since the device (https://datasheet.lcsc.com/lcsc/QST-QMC5883L-TR_C192585.pdf ) can do:
512x = 10 Hz
256x = 50 Hz
128x = 100 Hz
64x = 200 Hz
So why am I not getting 1 log entry per second when using 512x?
I’m really guessing here, but maybe only one oversample sensor reading can happen per esphome loop (~ 16ms ).
So maybe to oversample at 512 your update interval would been need to be about 9sec.
kouny
February 27, 2024, 11:12am
3
I think the oversampling is done in hardware, not in esphome, since it’s mentioned in the datasheet and it has a register value for setting it up, which would make no sense if it were done by esphome in software.
But thanks for trying
I hope we find out the cause of the issue! I dint want to program the device in Arduino to get the readings as expected
kouny
February 27, 2024, 6:51pm
4
I switched back to 512x while keeping 1s sampling rate and apparently it works as expected. I tried 0.1s as well, still 512x, and it works.
I guess there was a mismatch between the source code I was seeing and the binaries loaded into the device, set to 5s sampling rate.
All fine, no issues then.
