Recently I discovered, that trying to get bandwidth data from my qnap devices is not working anymore. I’m not sure, if it is a problem cuased by qnap or the integration, as I updated both recently.
Reading
- status
- cpu_usage
- cpu_temp
- memory_percent_used
- volume_percentage_used
- system_temp
- drive_smart_status
seems to work without error, however trying to get
- network_tx
- network_rx
result in an error.
The HA log shows:
Failed to fetch QNAP stats from the NAS
File "/usr/src/homeassistant/homeassistant/components/qnap/sensor.py", line 197, in update
self.data["bandwidth"] = self._api.get_bandwidth()
File "/usr/local/lib/python3.8/site-packages/qnapstats/qnap_stats.py", line 290, in get_bandwidth
default = resp["bandwidth_info"]["df_gateway"]
KeyError: 'bandwidth_info'
and
- Error adding entities for domain sensor with platform qnap
- Error while setting up qnap platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 383, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 588, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 615, in add_to_platform_finish
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 368, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 402, in _async_write_ha_state
state = self._stringify_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 374, in _stringify_state
state = self.state
File "/usr/src/homeassistant/homeassistant/components/qnap/sensor.py", line 288, in state
data = self._api.data["bandwidth"][self.monitor_device]
KeyError: 'bandwidth'
My config is:
- platform: qnap
host: !secret qnap_host
port: 443
ssl: true
verify_ssl: false
username: !secret qnap_user
password: !secret qnap_passwd
nics: eth4
monitored_conditions:
- status
- cpu_usage
- cpu_temp
- network_tx
- network_rx
- system_temp
Even if I omit “nics: eth4” I do not get any network card listed.
