I was using via yaml but just got a notice it is not supported. I noticed there is now an integration. When supply my IP, user, and pass it fails. I confirmed this works when going into the QNAP web interface. My thinking is because I use an Authenticator. Is that what is preventing this from being able to connect? If I temp disable that would it work? And if so, would adding it back break it again? Thanks
