QNAP sensor error KeyError: 'authPassed
I get the error KeyError: 'authPassed while trying to use the QNAP sensor with my QNAP TS-453A with firmware 4.3.4.0675
Failed to fetch QNAP stats from the NAS
  File "/usr/src/app/homeassistant/components/sensor/qnap.py", line 190, in update
    self.data["system_stats"] = self._api.get_system_stats()
  File "/usr/local/lib/python3.6/site-packages/qnapstats/qnap_stats.py", line 207, in get_system_stats
    force_list=("DNS_LIST")
  File "/usr/local/lib/python3.6/site-packages/qnapstats/qnap_stats.py", line 67, in _get_url
self._init_session()
  File "/usr/local/lib/python3.6/site-packages/qnapstats/qnap_stats.py", line 49, in _init_session
    if self._login() is False:
  File "/usr/local/lib/python3.6/site-packages/qnapstats/qnap_stats.py", line 57, in _login
    result = self._execute_post_url("authLogin.cgi", data, False)
  File "/usr/local/lib/python3.6/site-packages/qnapstats/qnap_stats.py", line 98, in _execute_post_url
    return self._handle_response(resp, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/qnapstats/qnap_stats.py", line 112, in _handle_response
    auth_passed = data['authPassed']
The configuration I have:
- platform: qnap
host: !secret qnap_ip
username: !secret qnap_username
password: !secret qnap_password
verify_ssl: false
monitored_conditions:
- status
- system_temp
- cpu_usage
- memory_free
- memory_used
- network_link_status
- network_tx
- network_rx
- drive_smart_status
- drive_temp
- volume_percentage_used
When I try from the command line of the HomeAssistant:
#!/usr/bin/env python3
from qnapstats import QNAPStats
from pprint import pprint
qnap = QNAPStats('ip', port, 'user', 'password')
pprint(qnap.get_system_stats())
I get the same error message. I made sure the password is correct even created an additional user with a simple password (e.g. not containing complex characters) to try but still got the same error message.
Hi – did you ever manage to solve this?
I’ve just tried the QNAP sensor and am getting the same error
  File "/usr/src/homeassistant/homeassistant/components/qnap/sensor.py", line 194, in update
  File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 207, in get_system_stats
  File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 67, in _get_url
  File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 49, in _init_session
  File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 57, in _login
  File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 98, in _execute_post_url
  File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 112, in _handle_response
KeyError: 'authPassed'
