QNAP Surveillance station
Hello
Does any one know if the Synology Surveillance station works on via the QNAP version of Surveillance station please?
Cheers
Mark
I don’t think so. I tried connecting my QNAP Surveillance Station using the Synology platform and got errors that the URL was invalid. So it appears that the URL the Synology Surveillance Station uses to retrieve images is different than what the QNAP uses.
Here is the error if you want the details.
2019-03-26 01:53:33 ERROR (MainThread) [homeassistant.components.camera.synology] Error when initializing SurveillanceStation
File “/usr/src/app/homeassistant/components/camera/synology.py”, line 53, in async_setup_platform
timeout=timeout
File “/usr/local/lib/python3.7/site-packages/synology/surveillance_station.py”, line 12, in init
self._api = Api(url, username, password, timeout, verify_ssl)
File “/usr/local/lib/python3.7/site-packages/synology/api.py”, line 59, in init
self._initialize_api_info()
File “/usr/local/lib/python3.7/site-packages/synology/api.py”, line 70, in _initialize_api_info
payload)
File “/usr/local/lib/python3.7/site-packages/synology/api.py”, line 192, in _get_json_with_retry
return self._get_json(url, payload)
File “/usr/local/lib/python3.7/site-packages/synology/api.py”, line 198, in _get_json
response = self._get(url, payload)
File “/usr/local/lib/python3.7/site-packages/synology/api.py”, line 185, in _get
verify=self._verify_ssl)
File “/usr/local/lib/python3.7/site-packages/requests/api.py”, line 75, in get
return request(‘get’, url, params=params, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/api.py”, line 60, in request
return session.request(method=method, url=url, **kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 533, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 640, in send
adapter = self.get_adapter(url=request.url)
File “/usr/local/lib/python3.7/site-packages/requests/sessions.py”, line 731, in get_adapter
raise InvalidSchema(“No connection adapters were found for ‘%s’” % url)
requests.exceptions.InvalidSchema: No connection adapters were found for ‘192.168.1.111:8080/webapi/query.cgi’
