Qnap zwave stick configuration
288/5000
hello I need a help if possible I have a qnap ts 453b where I installed docker and home assistant properly, I tried to follow the installation procedure of the zwave key on the site launching commands from the terminal but nothing … someone can help me thanks
I too am shrugging to install a zooz zst39 on my qnap. Direction on the zwave ui are not correct.
The developer said he cant help me as it is not device supported.
Has there been any progress on this? I decided to upgrade my zwave network and found out it wasn’t just swapping the usb stick. My old one worked following an older set of instructions. I’m assuming the driver needs to be updated or something
