Got it
That worked.
Nice!
I have orderd a new alarm system with this panel, hopefully it will arrive in the comming weeks so that I can try this app.
It works!!! Now to write some sensors in home assistant…
root@pi3:~ # mosquitto_sub -h hassio -u hassio -P <removed> -v -t "qolsys/#"
qolsys/panel/zone_event {"event":"ZONE_EVENT","zone_event_type":"ZONE_ACTIVE","version":1,"zone":{"status":"Open","zone_id":8},"requestID":"2150deb9-0d21-4381-8b22-64f674497c17"}
qolsys/panel/zone_event {"event":"ZONE_EVENT","zone_event_type":"ZONE_ACTIVE","version":1,"zone":{"status":"Closed","zone_id":8},"requestID":"2829aee0-52a3-447b-ba23-b965611d854f"}
If you use mqtt doesn’t this automatically create the sensors?
Yep it did, but it didn’t create all of them. Only the door sensors showed up. Here are others I have that didn’t show up:
"id": "xxx",
"type": "GlassBreak",
"name": "Kitchen Glass Break",
"group": "glassbreak",
"status": "Closed",
"state": "0",
"zone_id": 4,
"zone_physical_type": 12,
"zone_alarm_type": 0,
"zone_type": 19,
"partition_id": 0
"id": "xxx",
"type": "SmokeDetector",
"name": "Basement Smoke Detector",
"group": "smoke_heat",
"status": "Closed",
"state": "0",
"zone_id": 5,
"zone_physical_type": 9,
"zone_alarm_type": 9,
"zone_type": 5,
"partition_id": 0
"id": "xxx",
"type": "Motion",
"name": "Upstairs Motion Detector",
"group": "awayinstantmotion",
"status": "Closed",
"state": "0",
"zone_id": 8,
"zone_physical_type": 2,
"zone_alarm_type": 3,
"zone_type": 2,
"partition_id": 0
"id": "xxx",
"type": "Water",
"name": "Water",
"group": "WaterSensor",
"status": "Closed",
"state": "0",
"zone_id": 14,
"zone_physical_type": 8,
"zone_type": 15,
"partition_id": 0
I still haven’t even gotten mine to work yet. lol Might be because I don’t know much about mqtt
Do you have an MQTT broker already? If not, the Add-on works fine.
Well that’s a good sign, I got a topic for the appdaemon now. lol
So I am seeing this in the logs of appdeamon.
2021-04-08 16:21:10.413824 WARNING qolsys_panel: ------------------------------------------------------------
2021-04-08 16:21:10.414829 WARNING qolsys_panel: Unexpected error in worker for App qolsys_panel:
2021-04-08 16:21:10.415818 WARNING qolsys_panel: Worker Ags: {'id': '3216028e7f9b4f6dba70de4de7d53770', 'name': 'qolsys_panel', 'objectid': 'b3fa10c4654445349b5f93e1ba192a93', 'type': 'event', 'event': 'MQTT_MESSAGE', 'function': <bound method MQTTSubscriber.mqtt_zone_event_event_received of <qolsys_requests.MQTTSubscriber object at 0x7faf35be20>>, 'data': {'topic': 'qolsys/panel/zone_event', 'wildcard': '#', 'payload': ''}, 'pin_app': True, 'pin_thread': 0, 'kwargs': {'topic': 'qolsys/panel/zone_event', '__thread_id': 'thread-0'}}
2021-04-08 16:21:10.416637 WARNING qolsys_panel: ------------------------------------------------------------
2021-04-08 16:21:10.417801 WARNING qolsys_panel: Traceback (most recent call last):
File "/usr/lib/python3.8/site-packages/appdaemon/threading.py", line 936, in worker
funcref(args["event"], data, self.AD.events.sanitize_event_kwargs(app, args["kwargs"]))
File "/config/appdaemon/apps/ad-qolsys/qolsys_requests.py", line 57, in mqtt_zone_event_event_received
self.mqtt_zone_update_event_received(event_name, data, kwargs)
File "/config/appdaemon/apps/ad-qolsys/qolsys_requests.py", line 29, in mqtt_zone_update_event_received
zone = payload_json["zone"]
KeyError: 'zone'
2021-04-08 16:21:10.418659 WARNING qolsys_panel: ------------------------------------------------------------
Do you have mqtt configured? Are all the topics discreet?
I do have mqtt configured. The zigbee2mqtt and zwavejs2mqtt are showing up.
What do you mean discrete?
Can you post the config from apps.yaml?
Anyone using this in the UK ? (or EU)
I’m interested in if the panels are locked to an LTE carrier - they seem to be sold as AT&T Verizon etc. Would like it to work with a UK carrier obviously.
I have the AppDaemon integration running but no panel yet! Should it publish anything to MQTT in that scenario (I see the socket fail) - perhaps an LWT message…
I mean each of the topics configured in apps.yaml must be distinct from any other topic. That’s the first reason i’d imagine you’d have that error.
no it would not. it needs the panel config to do anything.
Give me a bit. I’m having some weird issues with the mqtt broker.
qolsys_panel:
module: qolsys_client
class: QolsysClient
mqtt_namespace: mqtt
qolsys_host: 192.168.7.1
qolsys_token: ABCDEF
qolsys_port: 12345 # Optional
request_topic: qolsys/requests # Optional
qolsys_info_topic: qolsys/panel/info # Optional
qolsys_zone_update_topic: qolsys/panel/zone_update # Optional
qolsys_zone_event_topic: qolsys/panel/zone_event # Optional
qolsys_alarming_event_topic: qolsys/panel/alarming # Optional
qolsys_disarming_event_topic: qolsys/panel/disarm # Optional
qolsys_disarm_code: 1111 # Optional - Required if you want to disarm the panel
qolsys_confirm_arm_code: False
qolsys_confirm_disarm_code: False
