Qolsys_panel integration problems
Hi Everyone!
I’m trying to get the QolsysGateway working, but im getting errors everywhere.
A whole mess of these.
2024-09-07 16:19:28.180923 WARNING AppDaemon: No app description found for: /config/apps/qolsysgw/mqtt/exceptions.py - ignoring
2024-09-07 16:19:28.182412 WARNING AppDaemon: No app description found for: /config/apps/qolsysgw/mqtt/updater.py - ignoring
This seems bad.
2024-09-07 16:19:28.239903 ERROR qolsys_panel: Task exception was never retrieved
and a lot of these.
uture: <Task finished name=‘Task-336’ coro=<ADAPI.call_service() done, defined at /usr/lib/python3.11/site-packages/appdaemon/adapi.py:1691> exception=ServiceException(‘Unknown service (mqtt/mqtt/subscribe) in call_service from qolsys_panel’)>
File “/usr/lib/python3.11/site-packages/appdaemon/adapi.py”, line 1762, in call_service
return await self.AD.services.call_service(namespace, d, s, kwargs)
File “/usr/lib/python3.11/site-packages/appdaemon/services.py”, line 169, in call_service
raise ServiceException(f"Unknown service ({namespace}/{domain}/{service}) in call_service from {name}")
ServiceException: Unknown service (mqtt/mqtt/subscribe) in call_service from qolsys_panel
2024-09-07 16:19:28.240284 DEBUG qolsys_panel: Calling listen_event for qolsys_panel
2024-09-07 16:19:28.241933 ERROR qolsys_panel: Task exception was never retrieved
future: <Task finished name=‘Task-338’ coro=<ADAPI.call_service() done, defined at /usr/lib/python3.11/site-packages/appdaemon/adapi.py:1691> exception=ServiceException(‘Unknown service (mqtt/mqtt/subscribe) in call_service from qolsys_panel’)>
2024-09-07 16:19:28.242311 DEBUG qolsys_panel: Calling listen_event for qolsys_panel
There is nothing in the MQTT Logs
2024-09-07 16:19:28.427386 DEBUG qolsys_panel: call_service: mqtt/publish, {‘namespace’: ‘mqtt’, ‘retain’: True, ‘topic’: ‘homeassistant/sensor/qolsys_panel_last_error/config’, ‘payload’: ‘{“name”: “Last Error”, “device_class”: “timestamp”, “state_topic”: “homeassistant/sensor/qolsys_panel_last_error/state”, “availability_mode”: “all”, “availability”: [{“topic”: “homeassistant/alarm_control_panel/qolsys_panel/availability”, “payload_available”: “online”, “payload_not_available”: “offline”}, {“topic”: null, “payload_available”: null, “payload_not_available”: null}], “json_attributes_topic”: “homeassistant/sensor/qolsys_panel_last_error/attributes”, “unique_id”: “qolsys_panel_last_error”, “device”: {“name”: “Qolsys Panel”, “identifiers”: [“qolsys_panel”], “manufacturer”: “Qolsys”, “model”: “IQ Panel 2+”}}’}
2024-09-07 16:19:28.427568 DEBUG qolsys_panel: call_service: mqtt/publish, {‘namespace’: ‘mqtt’, ‘retain’: True, ‘topic’: ‘homeassistant/alarm_control_panel/qolsys_panel/availability’, ‘payload’: ‘online’}
2024-09-07 16:19:28.427639 DEBUG qolsys_panel: call_service: mqtt/publish, {‘namespace’: ‘mqtt’, ‘retain’: True, ‘topic’: ‘homeassistant/sensor/qolsys_panel_last_error/state’, ‘payload’: None}
2024-09-07 16:19:28.427699 DEBUG qolsys_panel: call_service: mqtt/publish, {‘namespace’: ‘mqtt’, ‘retain’: True, ‘topic’: ‘homeassistant/sensor/qolsys_panel_last_error/attributes’, ‘payload’: ‘{“type”: null, “desc”: null}’}
2024-09-07 16:19:28.434305 DEBUG qolsys_panel: Data received (len: 3): ACK
2024-09-07 16:19:28.435881 DEBUG qolsys_panel: ACK - ignoring.
2024-09-07 16:19:28.446411 WARNING MQTT: Error calling Home Assistant service mqtt/mqtt/publish
2024-09-07 16:19:28.452647 DEBUG qolsys_panel: Encoding detection: ascii is most likely the one.
2024-09-07 16:19:28.453258 WARNING MQTT: Code: 400, error: 400: Bad Request
2024-09-07 16:19:28.497320 INFO qolsys_panel: Previous message repeated 1 times
2024-09-07 16:19:28.497555 DEBUG qolsys_panel: Data received (len: 7440):
apps.yaml
hello_world:
  module: hello
  class: HelloWorld
qolsys_panel:
  module: gateway
  class: QolsysGateway
  panel_host: 192.168.1.XXX
  panel_token: XXXXX
  panel_user_code: XXXXX
  mqtt_namespace: mqtt
  request_topic: qolsys/requests # Optional
  qolsys_info_topic: qolsys/panel/info # Optional
  qolsys_zone_update_topic: qolsys/panel/zone_update # Optional
  qolsys_zone_event_topic: qolsys/panel/zone_event # Optional
  qolsys_alarming_event_topic: qolsys/panel/alarming # Optional
  qolsys_disarming_event_topic: qolsys/panel/disarm # Optional
  qolsys_confirm_arm_code: False # Optional
  qolsys_confirm_disarm_code: False # Optional
  qolsys_arm_away_always_instant: False # Optional
  homeassistant_mqtt_discovery_topic: homeassistant/
  log_level: DEBUG
appdaemon.yaml
appdaemon:
  latitude:
  longitude:
  elevation: 2
  time_zone: America/New_York
  plugins:
    HASS:
      type: hass
    MQTT:
      type: hass
      namespace: mqtt
      client_host: 'core-mosquitto'
      client_port: 1883
      client_id: my-appdaemon
      verbose: true
      client_user: xxxxx
      client_password: xxxxxxxx
http:
  url: http://127.0.0.1:5050
admin:
api:
hadashboard:
