Hello ! I am trying to find why my setup does not works. I am looking at all my logs but can’t find why my Qolsys Panel is not detected in HA.
Here’s my current setup:
- Linux Ubuntu PC running
- HA in a docker container
- MQTT Mosquitto Broker with
apt install -y mosquitto
- Docker running appdeamon on port 5050 exposed
Using localhost
as MQTT hostname in HA and AppDeamon. Everythings seems to connect if I look at the logs. Same thing for AppDeamon where apps loads and shows as loaded on the UI. I disabled ufw
yesterday, nothing changed.
When I enable Control4 on my panel, nothing moves even if I reload everything in the 15 mins window before it gets disabled again.
Trying to find pointer where to look! Thank you
