First time poster here for what thats worth
I have setup the Qolsys Panel integration with appdaemon and MQTT and its working great but I am missing some sensors. The ones that are missing are contact sensors on my windows that are also shock sensors for glass breakage and my smoke detectors, when I look in the Devices list under Qolsys Panel and then look at “last Error” I see entries like the following for these sensors, is there some way to code these unknown sensors to be recognized?
This is a typical error message:
Type
UnknownQolsysSensorException
Desc
Sensor type ‘Smoke_M’ unsupported for sensor {‘id’: ‘678829’, ‘type’: ‘Smoke_M’, ‘name’: ‘Hallway Smoke Detector’, ‘group’: ‘smoke_heat’, ‘status’: ‘Closed’, ‘state’: ‘0’, ‘zone_id’: 18, ‘zone_physical_type’: 1, ‘zone_alarm_type’: 9, ‘zone_type’: 111, ‘partition_id’: 0}
And Another:
Type
Desc
Sensor type ‘Door_Window_M’ unsupported for sensor {‘id’: ‘CE81A4’, ‘type’: ‘Door_Window_M’, ‘name’: ‘Master Bed Window 3’, ‘group’: ‘instantperimeter’, ‘status’: ‘Closed’, ‘state’: ‘0’, ‘zone_id’: 12, ‘zone_physical_type’: 1, ‘zone_alarm_type’: 3, ‘zone_type’: 110, ‘partition_id’: 0
Thank you for any assistnace you can provide.
