QOS settings not taking in zigbee2mqtt
Hi there.
I want to set up QOS2 for all my devices. I have configured the zigbee2mqtt/configuration.yaml file to have every device with QOS2 but checking with MQTT explorer doesn’t show any working on that. What have I done wrong? Can none of my devices handle it?
Example sensor below:
  '0x00158d0002418813':
    friendly_name: Sensor - Contact - Kitchen Freezer
    homeassistant: {}
    optimistic: false
    qos: 2
Something else I’ve noticed that may be related. In the UI, if I try and add the QOS value under settings, it will disappear after few seconds. I will add the 2 and after a couple seconds will just go blank. A couple other fields were also acting strange and I couldn’t remove a setting so I just took it as an issue with the UI.
Last attempt at a bump in the hopes someone can help me.
