This is something I threw together and it seems to work just fine. I have my guest wifi automatically change on a weekly basis and that pushes the value to sensor.guest_wifi. (Yes I know it is unnecessary but this was to see if I could, and I can, so I did
I am not a python wizard so feel free to give feedback.
# Configuration.yaml
camera:
- platform: qrcode
value_template: "WIFI:S:GUEST_NETWORK;T:WPA/WPA2;P:{{states.sensor.guest_wifi.state}};;"
import logging
import io
import voluptuous as vol
from homeassistant.core import callback
from homeassistant.const import (
CONF_NAME, CONF_VALUE_TEMPLATE, ATTR_ENTITY_ID, EVENT_HOMEASSISTANT_START)
from homeassistant.components.camera import (PLATFORM_SCHEMA, Camera)
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.event import async_track_state_change
REQUIREMENTS = ['pyqrcode==1.2.1', 'pypng==0.0.18']
_LOGGER = logging.getLogger(__name__)
DEFAULT_NAME = 'qr_code'
# SCAN_INTERVAL = timedelta(seconds=2)
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Required(CONF_VALUE_TEMPLATE): cv.template,
vol.Optional(ATTR_ENTITY_ID): cv.entity_ids,
async def async_setup_platform(hass, config, add_devices, discovery_info=None):
"""Set up the QRCode image platform."""
name = config.get(CONF_NAME)
value_template = config.get(CONF_VALUE_TEMPLATE)
if value_template is not None:
value_template.hass = hass
entity_ids = (config.get(ATTR_ENTITY_ID)
or value_template.extract_entities())
add_devices([QRCodeCamera(hass, name, value_template, entity_ids)])
return True
class QRCodeCamera(Camera):
"""Representation of an QRCode image."""
def __init__(self, hass, name, template, entity_ids):
"""Initialize the QRCode entity."""
super().__init__()
self._hass = hass
self._name = name
self._template = template
self._entities = entity_ids
self._image = io.BytesIO()
self._refresh_()
async def async_added_to_hass(self):
"""Register callbacks."""
@callback
def qr_state_listener(entity, old_state, new_state):
"""Handle device state changes."""
self._refresh_()
@callback
def qr_sensor_startup(event):
"""Update template on startup."""
async_track_state_change(
self.hass, self._entities, qr_state_listener)
self.hass.bus.async_listen_once(
EVENT_HOMEASSISTANT_START, qr_sensor_startup)
@property
def name(self):
"""Return the name of the image processor."""
return self._name
@property
def should_poll(self):
"""Update the recording state periodically."""
return True
@property
def state(self):
return self._template.async_render()
def camera_image(self):
"""Process the image."""
return self._image.getvalue()
def _refresh_(self):
import pyqrcode
import png
qr_code = pyqrcode.create(self._template.async_render())
self._image.truncate(0)
self._image.seek(0)
qr_code.png(self._image, scale=6, module_color=[
0xff, 0xff, 0xff], background=[0, 0, 0, 128])
