Adding this for anyone who has same issue. I plan to add github issue as well but maybe can get it resolved.
I get below error with HA 2021.11.3 in docker
Platform error: image_processing
File "/usr/src/homeassistant/homeassistant/config.py", line 887, in async_process_component_config
platform = p_integration.get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 530, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 535, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 850, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/qrcode/image_processing.py", line 5, in <module>
from pyzbar import pyzbar
File "/usr/local/lib/python3.9/site-packages/pyzbar/pyzbar.py", line 7, in <module>
from .wrapper import (
File "/usr/local/lib/python3.9/site-packages/pyzbar/wrapper.py", line 144, in <module>
zbar_version = zbar_function(
File "/usr/local/lib/python3.9/site-packages/pyzbar/wrapper.py", line 141, in zbar_function
return prototype((fname, load_libzbar()))
File "/usr/local/lib/python3.9/site-packages/pyzbar/wrapper.py", line 120, in load_libzbar
libzbar, dependencies = zbar_library.load()
File "/usr/local/lib/python3.9/site-packages/pyzbar/zbar_library.py", line 65, in load
raise ImportError('Unable to find zbar shared library')
ImportError: Unable to find zbar shared library
I check and find below issue. seems it is temporary fix but longterm is add pyzbar or zbar to docker image
